DIY Tapped Oil Pan
Old Nov 16, 2008 | 07:30 PM
Dc295kid's Avatar
Default DIY Tapped Oil Pan
Any diy on how to tapp your own oil pan for turbo
if you do it yourself what fitting do you use for the oil pan thanks
Old Nov 16, 2008 | 07:51 PM
bobby taylor's Avatar
Default Re: DIY Tapped Oil Pan (Dc295kid)
i would take the pan off and weld an fitting in it!
most pans are to thin to just tap.
Old Nov 17, 2008 | 08:35 AM
dpetro1's Avatar
weld-on -10 AN bung
or do it without welding
i recommend using a -10AN bulkhead fitting
a -10AN bulkhead nut
and 2 -10AN stat-o-seals
1. mount turbo/dp and mock up return line, mark pan for return bung (high as possible)
2. remove the pan. using a unibit drill large enough hole (maybe 7/8")
3. cut off short end of fitting, stick fitting through the inside of the pan and tighten bulkhead nut from outside of pan. remember to use washers or stat-o-seals on each side
4. reinstall pan and install stainless return line.
there was an old wirte-up on here that showed the whole process. i did it this way and had a less-free weldless line for 3 years. (granted welding is much easier)
Old Nov 18, 2008 | 12:54 AM
Dc295kid's Avatar
thanks guy i planning on just weldings it too
Turbo_Mike
Apr 19, 2005 11:33 PM
dan89crxsi
Feb 24, 2004 10:43 AM
turbochic
May 6, 2003 02:15 PM
420aNT
Mar 9, 2003 10:26 PM
GruvyTune
Aug 21, 2001 09:37 PM
