Prelude 2.2 Turbo Holding in !!!
My car keeps holding in when it hits 5000rpm..... i boosted before but it worked fine...
now i purchased a skunk2 manifold and it has this problem... but maybe it can be something else..
Does anyone have any suggestions ?
Re: (Civicman86)
its keeping in...... if it hits the 5000rpm... it doesnt give its full power.... i lowered the boost to 10psi... its boosting 10psi... but it feels like something is holding it back.. when it hits the 5000rpm mark
Re: (dranican)
boost leak?, check all your vacc lines, and check for leaks, if it was working perfecr before the intake manifold, then something isnt tightend down right, check your couplers fromt he TB to piping, check all electrical plugs, made sure there not crossed up
Re: Prelude 2.2 Turbo Holding in !!! (Muckman)
I'm still blown away people post up problems and havent checked anything. Have you checked for boost leaks, have you checked for a vacuum leak, whats your boost gauge read at idle, whats your plugs look like, etc. At least post up a question and have some basic background info instead of just saying "holding in" after 5k which doesn't mean **** to anyone.
Re: Prelude 2.2 Turbo Holding in !!! (B6tPoweredMx3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tPoweredMx3 »</TD></TR><TR><TD CLASS="quote">Have it retuned afterwards?</TD></TR></TABLE>
If you havent done that then that could be it. The skunk2 flows more air in higher Rpms. Maybe your leaning around that rpm range.
Re: Prelude 2.2 Turbo Holding in !!! (dranican)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dranican »</TD></TR><TR><TD CLASS="quote">I have a VAFC...</TD></TR></TABLE>
thats probably why
thats probably why
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dranican »</TD></TR><TR><TD CLASS="quote">I have a VAF....</TD></TR></TABLE>
*clicks the X*
*clicks the X*
Re: Prelude 2.2 Turbo Holding in !!! (RudeLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">Did you try the Citrate of Magnesia?</TD></TR></TABLE>
that should let it out
or go easy
or go easy
crew08 (girlygirlracer)
10-13-2005 07:58 PM
