turbo problems???
Old Aug 27, 2009 | 11:51 AM
accord99power's Avatar
Default turbo problems???
I have been running 10 lbs of boost, recenlty i noticed that i dont have the same pull as usual, so i have been watching the boost gauge and i am hitting about 7-8 lb. i havent touched the manual boost controller. I looked for anything obvious and found nothing.
i know this stuff can be hard to diagnosis, but what are somethings you guys would check first?? thanks turbo guru's!
p.s. setup in signature and in my garage.
Old Aug 27, 2009 | 12:16 PM
Ls_dx's Avatar
Default Re: turbo problems???
check the system for boost leaks. tighten up all your clamps.
Old Aug 27, 2009 | 12:19 PM
boostedEF91's Avatar
did you try turning up the boost a lil to see if it holds back at 10psi.. other than that there is most likely a small leak somehwere.
Old Aug 27, 2009 | 02:32 PM
thanks alot guys yeah i dont have the best quality plumbing ill check it out some more. since i don't boost in neutral any ideas as to a way to test? or just pull them off and check?
Old Aug 27, 2009 | 02:34 PM
ill check this out to i assume i would get a surge though right? if theres an actually leak? kinda dont wanna surge it over the 10 psi see what i mean?
Old Aug 27, 2009 | 06:23 PM
oodie's Avatar
With just a good eye and feeling couplers your should be able to find it. I also do mine with the car on and also listen.
Old Sep 8, 2009 | 06:35 PM
Ahh found it, well kinda funny actually. I was messing with the couplers etc. couldnt find anything, well i kinda forgot which way i had my boost controller, hit 15 lb's on a run and boom! i was like ohh crap. Actually a good thing because i found the loose coupler, fixed it. i was hitting 9 lbs solid afterwards, just have to tune the boost controller again, no biggie, though.
1sic3dr
Aug 11, 2007 03:28 PM
nzrnk
Apr 5, 2005 04:40 AM
r1lorenzini
Feb 19, 2004 11:54 AM
crucial si
May 31, 2003 08:46 PM
PolosportZ81
Mar 12, 2003 03:35 PM
