Need a material I can make gaskets out of!
Old Nov 15, 2003 | 01:39 PM
GPoodle
Guest
Posts: n/a
Default Need a material I can make gaskets out of!
Hey all, Im looking for some sort of high-temp material I could find at like Home Depot or some shop like that I could cutup/drill to make gaskets out of.
I havent taken a trip there and looked for any high heat thin material, but if anyone has anything they can suggest, let me know!
Thanks
Old Nov 15, 2003 | 01:47 PM
falcongsr's Avatar
What is this crap?
Default Re: Need a material I can make gaskets out of! (GPoodle)
gaskets for what? pepboyz has gasket material.
Old Nov 15, 2003 | 02:17 PM
GPoodle
Guest
Posts: n/a
Doh sorry probably should have said...
In paticular for oil feed/return on turbo parts, and the wastegate gasket and exhaust/intake gaskets on the turbo.
Old Nov 15, 2003 | 02:30 PM
Evil EG's Avatar
Default Re: (GPoodle)
pop cans...
rjardy's Avatar
Dont run gaskets on your turbo. They are 2 machined surfaces and if it is snug it will not leak. the return line you will definatly want to run an gasket. but yeah you can get them at the parts store, like 3 bucks for a sheet of gasket material.
Rob
Old Nov 15, 2003 | 02:39 PM
pip9's Avatar
Default Re: (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">Dont run gaskets on your turbo. They are 2 machined surfaces and if it is snug it will not leak. the return line you will definatly want to run an gasket. but yeah you can get them at the parts store, like 3 bucks for a sheet of gasket material.
Rob</TD></TR></TABLE>
that's what i did. My gaskets on my wg/turbo etc.. all leaked so i took them out and never had a problem after it. As for the return lines, i went to pepboys and bought a sheet of this gasket material for a couple bucks and that worked pretty good
Old Nov 15, 2003 | 04:05 PM
GPoodle
Guest
Posts: n/a
Sounds like a plan!
Thanks for the response guys, helps tons. :tu:
95dc2teg
Jul 17, 2006 01:26 PM
ssrcx94
Dec 18, 2005 10:05 AM
88crxhfb16
May 21, 2005 06:46 AM
4-banging
Mar 15, 2004 12:03 PM
FOrSfEd
Jan 11, 2004 10:24 AM
