oil feed line problem
Old May 5, 2004 | 07:42 AM
sohc_vtec 2NR's Avatar
Default oil feed line problem
After installing my greddy kit, i had a leak in my oil feed line and i finally got the time to fix it, but as usual i run into problems. Here's a picture:
Problem: the oil line won't fit into the banjo fitting, the oil line is smaller than the banjo fitting
Possible Solution #1: tighten the f*ck out of it and hope it seals...
Possible Solution #2: buy some sort of "adapter/fitting/connector" that will connect both pieces together...
So where do you think i can find an adapter/fitting/connector? The line is from fast-turbo.com
Old May 5, 2004 | 08:08 AM
Flamenco-T's Avatar
Default Re: oil feed line problem (sohc_vtec 2NR)
Hi,
Here's how you install the oil feed line to the turbo.
Identify the fitting that matches your turbo, as the pic shown below, your fitting should be the second one from the left.
Screw the fitting on there and then connect the female end of the line to the other end of the fitting.
hope this helps.
Modified by Flamenco-T at 1:20 PM 5/5/2004
Old May 5, 2004 | 08:41 AM
G
sh!t happens.
Default Re: oil feed line problem (Flamenco-T)
^^^^^^ what he said or just get a different tee fitting that is better.
Old May 5, 2004 | 11:02 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_vtec 2NR &raquo;</TD></TR><TR><TD CLASS="quote">After installing my greddy kit, i had a leak in my oil feed line and i finally got the time to fix it, but as usual i run into problems. Here's a picture:
So where do you think i can find an adapter/fitting/connector? The line is from fast-turbo.com</TD></TR></TABLE>
the bango bolt you have is non-tapered and even if you crank the crap outta the fitting and get it on there, i garuntee it WILL leak.
just get the right adapter for the turbo.
mike
Old May 5, 2004 | 11:14 AM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
Modified by Flamenco-T at 1:20 PM 5/5/2004</TD></TR></TABLE>
just to clarify you connect that fitting pictured to the banjo fitting?
I don't see how that works...
Old May 5, 2004 | 11:27 AM
MikeMAN's Avatar
Default Re: oil feed line problem (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
no, you dont use the banjo fitting at all...you put one of the above turbo fittings ON the turbo itself (removing the banjo fitting)
mike
Old May 5, 2004 | 11:32 AM
igo4bmx's Avatar
Default Re: oil feed line problem (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">no, you dont use the banjo fitting at all...you put one of the above turbo fittings ON the turbo itself (removing the banjo fitting)
mike</TD></TR></TABLE>
correct me if i'm wrong but doesn't the banjo fitting on the greddy kit act as an oil resitrictor?
cuz if thats true i wouldn't want to remove it
Old May 5, 2004 | 12:01 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_vtec 2NR &raquo;</TD></TR><TR><TD CLASS="quote">but as usual i run into problems. </TD></TR></TABLE>
I see the problem.. Your using angelfire to host images.. I cant see the pic but since Stan is here to help you dont need me..
Old May 5, 2004 | 01:57 PM
MikeMAN's Avatar
cuz if thats true i wouldn't want to remove it</TD></TR></TABLE>
it might ACT as one, but it isn't there because of that. Easy way to make a 90 degree fitting, so greddy plopped it on there. And the inside of the fittings are small enough to restrict, they work fine. They aren't on numerous 400-600whp civics for nothing
mike
Old May 6, 2004 | 08:55 AM
jmagner's Avatar
yeah theres really no reason the oil feed should be restricted at all.
Old May 6, 2004 | 09:40 AM
FwdCivicHatch's Avatar
Default Re: oil feed line problem (jmagner)
the banjo fitting does not restrict the oil flow, it if did it would be called a restrictor. And some people use restrictors on the oil feed because their turbo is smoking, usually to big of an oil feed line. if its a -03an line you shouldn't have any probs.
Old May 6, 2004 | 09:42 AM
Default Re: oil feed line problem (FwdCivicHatch)
also, never ever do this<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_vtec 2NR &raquo;</TD></TR><TR><TD CLASS="quote">
Old May 6, 2004 | 10:32 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch &raquo;</TD></TR><TR><TD CLASS="quote">also, never ever do this</TD></TR></TABLE>
yes, trust me...it will still leak hehe
mike
PinoyDelS0l
Aug 30, 2009 12:43 AM
JohnData
Nov 18, 2007 05:39 PM
iHOPEyouCHOKE
May 27, 2006 09:24 AM
B16Civic93
Mar 10, 2005 03:24 PM
harryg
Sep 10, 2003 07:21 PM
