Oil Feed line Connection Problem?
Old Aug 28, 2009 | 07:05 PM
PinoyDelS0l's Avatar
Default Oil Feed line Connection Problem?
Okay, so before I started my car. I primed the lines with oil. So after I finished priming my lines, the car started right up.. The turbo was running fine, everything was working correctly. Until i noticed small leaks of oil coming out of the oil feed line. Its the part that connects to the nipple on the feed line flange. I posted a picture and circled it in red to show you where it was leaking oil from. The line was screwed on tightly on the nipple and no oil was leaking on the nipple only on the line that I circled red at. I want to know, should there be alot of play on that spinning part thats on the line? Because I noticed that there was a gap on the spinning part on the line. Im not sure if that should be sealed or if its okay to be slightly spaced away from the line? But it has a lot of spinning play on the feed line.. Please help me soon, thank you!
Old Aug 28, 2009 | 08:16 PM
single slam 12's Avatar
Default Re: Oil Feed line Connection Problem?
Get rid of that oil line kit they are horrible and they tend give alot of problems and the kink easily.
Old Aug 28, 2009 | 08:27 PM
what brand do you suggest?
Old Aug 28, 2009 | 08:29 PM
But is there suppose to be soo much play on that spinning thing on the feed line???
Old Aug 28, 2009 | 08:35 PM
Dude they suck trust me i think donny at e.s.t performance has the oil line in stock. i saw one there if not get it made real quick i'll see what i can get for you..
Old Aug 29, 2009 | 11:53 AM
bump still need some answers about the play on the spinning part.
Old Aug 29, 2009 | 01:38 PM
Turbo B18C EJ6's Avatar
looks from here in your pic that the fitting you circled is bent, ive seen that happen on alot of hydraulic lines.
Old Aug 29, 2009 | 01:53 PM
1992Si's Avatar
No, should not be loose there.
Old Aug 29, 2009 | 01:54 PM
oodie's Avatar
Check the vendor on here Fast-Turbo His oil lines are real good. That seems to look like one of the lower quailty ones
Old Aug 29, 2009 | 03:23 PM
Alright thanks guys, shouldnt there be a piece of rubber or something in the spinning part?
Old Aug 29, 2009 | 03:50 PM
1992Si's Avatar
I think that's a crimp on fitting.
earlsplumbing.com
is who we use for our lines if you want to make your own, it's easier then it looks.
Old Aug 29, 2009 | 06:13 PM
i getz da chewin's Avatar
X2 great product and fast shipping
Old Aug 29, 2009 | 10:05 PM
omiehomie's Avatar
hell yea bump for stan @ fast turbo. excellent customer service and stupid fast shipping
Old Aug 29, 2009 | 10:26 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yes, that is normal for a JIC connection. The play will tighten up after you tighten the nut down.
Old Aug 30, 2009 | 12:43 AM
See thats what i did, i tighten everything down to see if that will close the gap between the spinning part and the feed line, and the oil just kept dripping away through the open crack of the spinning part?
B18 CYA
Apr 21, 2004 04:34 PM
eg6_lsi
Mar 18, 2004 04:46 PM
beepy
Mar 1, 2004 09:26 PM
