Oil feed line problems
Old Sep 10, 2003 | 03:27 PM
harryg's Avatar
Default Oil feed line problems
First of all, threading the feed line onto the connector on a t3/t04e (revhard mani) while the assembly is on the car is nearly impossible, takes about an hour to take it on or off. Here's the problem, when I connect the stainless steel line to the thread on the turbo and start the car, it leaks oil at the spot where the stainless line is crimped into a connector. This is the second line I've used, with the same results. Is it possible that it's just not tight enough on the turbo? Or is it possible that the oil return is kinked, sending pressure back up through the oil feed and thus leaking out of the fitting?
Any advice would be very appreciated.. I'm getting sick of this ****.
Old Sep 10, 2003 | 03:30 PM
Jared's Avatar
Default Re: Oil feed line problems (harrytg)
Are you using teflon tape on the threads?
Old Sep 10, 2003 | 03:33 PM
harryg's Avatar
Default Re: Oil feed line problems (Jared)
I was told not to use teflon on the fitting that goes into the turbo, so no.. I'm not.
Old Sep 10, 2003 | 07:19 PM
harryg's Avatar
..bump.. any other ideas?
Old Sep 10, 2003 | 07:21 PM
lazerus's Avatar
it sounds like the oil feed is made wrong, or has the wrong type of fittings, i think pictures of everything are going to help diagnose it best.
PinoyDelS0l
Aug 30, 2009 12:43 AM
CivicDude2k4
Sep 5, 2006 08:24 PM
2LiterTurboSeR
Feb 27, 2006 02:38 PM
delslowh23
Feb 28, 2004 04:59 PM
