oil return line kinking?
Old May 27, 2006 | 05:03 AM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default oil return line kinking?
i just recently installed a turbo kit on my d16z6, the car has only been driven about a mile since then.. and now i'm noticing a blueish/white smoke sometimes when i take it out for a few minutes.. i'm noticing oil on the exhaust side of my turbo every so often, which leads me to belive my oil line is kinking up, the oil line is stainless steal braided that i'm using now-and it seems to be bending a bit in the middle which looks as if it could be a 'kink'.
does anyone know a solution to my problem? TIA.
mike
pics:
Modified by iHOPEyouCHOKE at 6:48 AM 5/27/2006
Old May 27, 2006 | 06:28 AM
StolenTeg's Avatar
Default Re: oil return line kinking? (iHOPEyouCHOKE)
Make the oil line a little bit shorter
Old May 27, 2006 | 06:33 AM
* B A N N E D *
Default Re: oil return line kinking? (StolenTeg)
make it shorter but what fittings would i need? i suck at life.
Old May 27, 2006 | 06:41 AM
kKdARIAN's Avatar
Vice President/CEO
you should be able to cut the braided line that comes off the drain from the turbo. Make it shorter then re-fit the same fitting that is on there to the braided hose.
When you cut the braided line, wrap the portion that you are going to cut in some electrical tape, or duct tape or something to prevent fraying. Use a hacksaw it works best.
Also i would reccomend getting some small clamps to get a tighter fit on the hose to the fitting.
-kenny
Old May 27, 2006 | 06:54 AM
* B A N N E D *
Default Re: oil return line kinking? (kKdARIAN)
this **** is stiff as expletive, if i cut it. hows it going to reach
ramennoodles's Avatar
you can also use a 45degree fitting from the turbo
Old May 27, 2006 | 07:06 AM
* B A N N E D *
Default Re: oil return line kinking? (ramennoodles)
lets see if i can find a 45 fitting around here-hopefully i wont have to order it
Old May 27, 2006 | 07:30 AM
StolenTeg's Avatar
The striaight fitting is fine, your like is too long
Old May 27, 2006 | 07:57 AM
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHOPEyouCHOKE &raquo;</TD></TR><TR><TD CLASS="quote"> i suck at life.</TD></TR></TABLE>
, get a 45 off the turbo
Old May 27, 2006 | 09:00 AM
B18EG6's Avatar
Default Re: oil return line kinking? (boostedej1)
guess who is home from schooooollll
[seb]
lemme know if you need help ill see what i can do.
Old May 27, 2006 | 09:16 AM
shortyz21's Avatar
Default Re: oil return line kinking? (B18EG6)
why dont u move the piece in your oil pan over to where the turbo is, then its much simpler.
when u braze the fitting into the pan angle it up, then u dont have to expletive around with 45's
also. i hope you use clamps
Old May 27, 2006 | 09:24 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">guess who is home from schooooollll
[seb]
lemme know if you need help ill see what i can do. </TD></TR></TABLE>
yes, i need help. i need help selling this car. i'm sick of dealing with it and i have no ******* patience
welcome back btw.
PinoyDelS0l
Aug 30, 2009 12:43 AM
CivicDude2k4
Sep 5, 2006 08:24 PM
2LiterTurboSeR
Feb 27, 2006 02:38 PM
