The Official SOHC Supercharger thread...
Old Dec 16, 2006 | 06:51 PM
  #601
Jaker's Avatar
Default Re: (STREETWERKZ)
that's what i like to hear. the D16y7 valves are so much larger than the d16a6. i was gonna do this too if i stuck it out with a D series. </TD></TR></TABLE>
Only problem is the Y7 OEM cam is an absolute POS.
Old Dec 16, 2006 | 08:13 PM
  #602
STREETWERKZ's Avatar
Default Re: (Jaker)
i hear that..... i wonder what the sohc ZC cam would do with that head and those valves?
makes me want to experiment with the sohc again.
Old Dec 16, 2006 | 08:32 PM
  #603
Tad's Avatar
Tad
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">
This was with the built motor and the Endyn M62 D series kit. Eagle rods, Rollerwave pistons, D16Y7 head with stock cam, Skunk2 Ti retainers, D16Y8 intake valve springs (the Y7 head uses the same springs on both exhaust and intake, whereas the Y8 uses the same Y7 exhaust springs, but stiffer intake springs). Needless to say, it lived a relatively short life (3 weeks) before taking a really hard detonation hit caused by fuel starvation at an autocross which nuked the posted sleeve on #4 cylinder. I still haven't rebuilt it (5 months now).
aww, that's a bummer.
were u running the stock fuel pump?
maybe it's time to upgrade.
Old Dec 17, 2006 | 08:17 AM
  #604
daveb91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">i hear that..... i wonder what the sohc ZC cam would do with that head and those valves?
makes me want to experiment with the sohc again. </TD></TR></TABLE>
And how do you plan on doing that? ZC is more like A6 the Y7 is totally different. Cams DONOT interchange. The y7 sucks, bigger valves dont mean anything there is more to a head than valves.
Old Dec 17, 2006 | 08:22 AM
  #605
Default Re: (daveb91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveb91 &raquo;</TD></TR><TR><TD CLASS="quote">And how do you plan on doing that? ZC is more like A6 the Y7 is totally different. Cams DONOT interchange. The y7 sucks, bigger valves dont mean anything there is more to a head than valves.</TD></TR></TABLE>
you 100% sure on your info there?
ive bolted D15b7 (92-95) heads onto a6 blocks. these have larger valve too. and YES, it made more power.
i know there is more to a head than valves... i never said i wouldnt upgrade the valve train with it.
Old Dec 17, 2006 | 08:33 AM
  #606
Jaker's Avatar
There is a ZC that is Y7 based. I've been told the cam is a direct fit into the USDM Y7 head. I've also been told the Y7 based ZC cam is an improvement over the USDM Y7 cam. How big, or is it for real? I don't know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">
maybe it's time to upgrade.</TD></TR></TABLE>
I'm running the low pressure 255lph Walbro, and the gas tank has some custom fab'd baffles in it. I guess the power and traction was too much for 1/8 of a tank. Live and learn.
Old Dec 17, 2006 | 09:24 AM
  #607
Tad's Avatar
Tad
maybe it's the custom baffles man..
never heard of a stock gas tank not working well enough before.
Old Dec 17, 2006 | 10:16 AM
  #608
Jaker's Avatar
Default Re: (Tad)
Early EFs had some trouble using all the gas in the tank under racing conditions. My 89 hatch could not be autocrossed with anything less than 5/8s of a tank, or it would starve on long fast corners or long (6 or more cones) slaloms. Once I put the baffles in the tank, I could run 1/8 of a tank without starvation. That was before the BIG tires and the extra power.
Old Dec 20, 2006 | 05:13 PM
  #609
daveb91's Avatar
Default Re: (Jaker)
The Usual ZC that everyone refers to (basically A6) cam will not go into a Y7.
And the B7 and A6 have the same size valves.
http://www.knology.net/~jediklc/specs.htm
Old Dec 20, 2006 | 05:33 PM
  #610
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Tad)
Bisi sent this to me today.. thought you guys might like it yourselfs...
bisimoto.com
Old Dec 20, 2006 | 07:11 PM
  #611
1 Fly SI's Avatar
Default Re: (S@nt0s)
anyone have a idler pulley they want to get ride of?
Old Dec 20, 2006 | 08:06 PM
  #612
Jaker's Avatar
http://www.knology.net/~jediklc/specs.htm</TD></TR></TABLE>
I am not reffering to the 88-91 based ZC. There is one that is based on the 96-00 engine.
http://cgi.ebay.com/ebaymotors...sting
Old Dec 21, 2006 | 07:52 PM
  #613
1989CivicSi's Avatar
Default Re: (Jaker)
Hey guys, quick question but will I have any troubles bolting in a JRSC from a 97 Civic 4 door (SOHC non-vtec) into my 1989 Civic Si Hatch (SOHC ZC non-vtec)?
I'd just use the same belt, right?
Reason being is I just picked up a virtually complete JRSC in great condition for a killer deal in great condition .
Thanks a lot guys!
Edit: Forgot to ask, but what size diameter is the stock boost pulley on JRSC's? Just want to make sure I buy the right belt .
Old Dec 21, 2006 | 09:22 PM
  #614
1 Fly SI's Avatar
Default Re: (1989CivicSi)
I believe you are gonna have to change out the manifold. Isn't that what you did batman?
Old Dec 21, 2006 | 09:47 PM
  #615
Default Re: (1 Fly SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Fly SI &raquo;</TD></TR><TR><TD CLASS="quote">I believe you are gonna have to change out the manifold. Isn't that what you did batman?</TD></TR></TABLE>
no, he just changed the snout pulley.
but honestly.... if you shim the pullies to the right spacing, you dont have to change any pulley.
Old Dec 21, 2006 | 11:36 PM
  #616
How would you go about shimming the pullies?
Thanks!
Old Dec 22, 2006 | 11:22 AM
  #617
1 Fly SI's Avatar
but honestly.... if you shim the pullies to the right spacing, you dont have to change any pulley. </TD></TR></TABLE>
My bad I was thinking of some one else.
Old Dec 22, 2006 | 04:01 PM
  #618
washers work wonders.
Old Jan 4, 2007 | 02:12 PM
  #619
solorex's Avatar
I have been piecing together my JRSC for the last couple of months and I have a couple of questions. Maybe you guys can help, this post has been pretty informative.
Currently I have a y8 in the car. For rules, I have to build up a d16a6 bottom end (no choice on this). I already have a block available and bought some scat rods and I thinking about pistons that will give 10:1 compression. What head should I use? I have a port and polished a6 head that I could put together, or should I stay with the y8 head? What's going to make have the most potential and make the most power?
From what I have read here it seems like the non-vtec heads are best. Just wondering...
TIA
Old Jan 29, 2007 | 01:55 PM
  #620
Savage211's Avatar
Default Re: The Official SOHC Supercharger thread... (8atman)
bump... let's get this going again.
Old Feb 18, 2007 | 09:57 AM
  #621
daveb91's Avatar
Default Re: The Official SOHC Supercharger thread... (Savage211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Savage211 &raquo;</TD></TR><TR><TD CLASS="quote">bump... let's get this going again. </TD></TR></TABLE>
Bump this thing some how got knocked out of my subscribed list!!
Old Feb 18, 2007 | 08:23 PM
  #622
civicflow's Avatar
Default Re: The Official SOHC Supercharger thread... (daveb91)
I read thru this whole thread. some good info. now I am just waiting for rexman to ship me my blower I bought off of him for my d16z6. can't wait to be blown
Old Feb 19, 2007 | 06:36 AM
  #623
Savage211's Avatar
Default Re: The Official SOHC Supercharger thread... (civicflow)
what combo does it take for a Y8 to run 9-10 pounds? i'm not sure which crank to which pulley etc.. to match them together with.
Old Feb 20, 2007 | 09:04 PM
  #624
daveb91's Avatar
In case you guys didnt see it in the other SC thread there was some question if the LHT intercooler was being made for the SOHC. John at lht said YES it was still being produced.
Old Feb 27, 2007 | 06:51 AM
  #625
civicflow's Avatar
Default Re: The Official SOHC Supercharger thread... (SeaDooOver)
My supercharger should be here today or tommorrow. Thanks to Rexman. I will be blowin a d16z6 w/crower stage 2 turbo cam, crower springs/retainers, new oe valves, and minor headwork. I won't actually be installing it til it warms up and I find a new beater.
