The Official SOHC Supercharger thread...
Old Oct 9, 2006 | 10:11 AM
  #226
8atman's Avatar
Default Re: (8atman)
https://honda-tech.com/zerothread?id=1775717
Old Oct 9, 2006 | 09:57 PM
  #227
STREETWERKZ's Avatar
weird that no matter what motor a jrsc is on, whether its vtec or not, the numbers are all pretty similar.
Old Oct 10, 2006 | 07:28 AM
  #228
ZacCarter's Avatar
sohc vtec sucks, I am pretty sure the hicam lobes are the same on a vtec motor as on a nonvtec lobe. Maybe a more agressive cam with larger exhaust valves would make a difference.
Old Oct 11, 2006 | 08:44 PM
  #229
robx7fcna's Avatar
Hey guys, thought I would bump up this thread with a couple of questions for you JRSC gurus... Read all 10 pages and gaied a bunch of knowlege
I just picked up a D16y8 JRSC kit with the crank pulley boost upgrade for $900 CAD. I plan to put this on my stock internaled D16a6 (CRX Si). I have had my PM6 socketed, bought DSM 390's, 190 lph pump, so I am pretty much setup.
The problem is, the D16y8 blower pulley seems to be inset towards the motor and about a 1/2" out of alignment from the other pullies (idlers, alt, crank pulleys all line up.) A friend of mine told me that it was like this to clear the shock tower and master cyl on EK's.
-Can this y8 blower pulley be made to work on my setup (spacer??) I am thinking prolly not since it would throw things out of balance...
- From what I read on here JR has discontinued pullies, right? Or is that just the upgrade pullies? Any other souces to get pullies besides Endyn and JR??
Thanks in advance for your help. -Rob-
Old Oct 11, 2006 | 08:56 PM
  #230
JICEK9's Avatar
Default Re: (robx7fcna)
I'm not sure, you might want to call Jackson. You may need to get the proper IM from Jackson for your exact appication. The m45 blower would be the same, but the IM may be diffent.
Old Oct 11, 2006 | 08:57 PM
  #231
SiRay13's Avatar
can you post a picture?
Old Oct 11, 2006 | 09:22 PM
  #232
robx7fcna's Avatar
sure, I'll try to get one up by tomorrow night at the very latest. It is just on my mock up motor, it will be pretty easy to spot.
Thanks for the quick replys guys...
I am pretty sure the intake manifold is the same, but I could be wrong... I am new to this S/C stuff!
Old Oct 11, 2006 | 09:23 PM
  #233
Default Re: (SiRay13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRay13 &raquo;</TD></TR><TR><TD CLASS="quote">can you post a picture?
i think it'll still fit.
i used a 92-95 civic EX SC on my D16a6.
Old Oct 11, 2006 | 10:06 PM
  #234
robx7fcna's Avatar
Ok, I just ran into the garage and snaped a couple of pics... http://www.imagestation.com/al...60093
Front
Kinda crappy shot, but you can see the top of the blower pulley above the engine mount (to the left of the stud sticking up) and how far the other pullies stick out.
Top
As you can see, it looks like the blower pulley is in the furthest, then they seem to progressively step out further.
Back
The money shot... you can see how much it is out here...
The Y8 boost upgrade pulley compaired to the stock a6 pulley... See how it's inset a bit?
the blower pulley, is 3.8 a stock size?
This was the car last year, built A6/Z6 minime forged internals, greddy kit.... cracked cyl sleeve #3
Now back to stock, waiting to be modded again!
Sorry for the crappy pics, but I hope that helps what I am trying to explain.
-Rob-
Modified by robx7fcna at 11:16 PM 10/11/2006
Old Oct 12, 2006 | 07:49 AM
  #235
rmcdaniels's Avatar
Hey Rob.
The 99-00 Y8 uses a different manifold (JR part #051-647) than the earlier Y8's and A6's use (JR part #051-417) , although all Y8's use the same blower/pulley setup, while A6's use a 4-rib 3.4" blower pulley, although since it uses the same intake manifold as an earlier Y8, I'd guess that the offset of the blower pulley is the same as long as they use OEM crank pulleys with similar offsets (if A=B and B=C, then A=C, thank God for H.S. algebra!). If you have a Y8 crank pulley, then I'm guessing you'd just need an earlier Y8 or A6 manifold to make it all line up right. Unfortunately JR charges $191.67 for the new manifold.
Good luck with it,
Roger
Old Oct 12, 2006 | 03:11 PM
  #236
robx7fcna's Avatar
Default Re: (rmcdaniels)
Thanks for the info Roger
I have a plan...
A friend of mine has a Y8 in his CRX and also just bought a JRSC but it is for a Z6... Maybe I will trade him intake manifolds/pullies. Then hopefully it will workout.
Old Oct 16, 2006 | 07:33 PM
  #237
JICEK9's Avatar
bump
Old Oct 17, 2006 | 05:20 AM
  #238
creechrr's Avatar
Default Re: (JICEK9)
Let's keep it going.
Old Oct 17, 2006 | 04:45 PM
  #239
8atman's Avatar
Default Re: (creechrr)
for sure I will have more to talk about once joe and i get together on my install. Should take place at the begining of next month cant wait.
Old Oct 18, 2006 | 04:05 PM
  #240
buy the parts you need. get a tuner. then we'll talk.
Old Oct 18, 2006 | 06:46 PM
  #241
Scracho's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">who cares! driving around town I barely get OVER 4500rpms! If I was building a drag car, sure it would have a turbo under the hood. but it would not be a sohc. but for many applications, the SC is the wise choice. for every day driving, you can't beat them. a sohc SC'd car is very fun car for a daily driver. cheap and reliable.
up for SC </TD></TR></TABLE>
I think most people forget that they spend 90%of their driving time on the street and not the track. Even then which track??? I love to AutoX and the supercharged Honda's, Miata's, Etc are consistently faster and more reliable than the turbo'd cars. The other thing that I still can't understand is what is the point of having anything over 200whp in a small light car like our Civic's??? First of all if you can't hook up for the first 2 gears that's a waste. Secondly when does HP out weigh suspension and braking capabilities? Maybe I think this way cause I don't drive in a straight line everywhere I go!
Old Oct 18, 2006 | 07:36 PM
  #242
PickleTeg's Avatar
Default Re: (Scracho)
I am in total agreement with both of you. For a street car a JRSC is hard to beat. NO one builds a JRSC car to be a 1/4 mile monster. If you did you would be a dumbass. I have a LSD and with the power and torque I have (see sig) I still roast 1st pretty hard sometimes. This is on 205/45/16 Yoko ES 100s. I say bring on the 350 WHP FWD turbo car out on the street and watch me light your *** up from a stop cause you get no traction.
Old Oct 19, 2006 | 05:41 PM
  #243
pumpkinkidd's Avatar
Default Re: (PickleTeg)
Old Oct 19, 2006 | 06:19 PM
  #244
8atman's Avatar
yup yup yup SCers are a great compliment to our lightweight fwd civics.
Old Oct 19, 2006 | 06:28 PM
  #245
superchargers are whack. turbo for the win!
Old Oct 19, 2006 | 06:31 PM
  #246
8atman's Avatar
Default Re: (STREETWERKZ)
Its all about boobercharging guys trust me
Old Oct 19, 2006 | 10:07 PM
  #247
soldier604's Avatar
i've used the search but couldn't really find much on the d16y7. i just wanted to know what kind of opinions you guys have on puting a jrsc on the stock d16y7. im aiming at about 150whp would i need to spend alot of money to upgrade?? or am i asking too much power on the stock d16y7? any input would be appreciated
thank
Old Oct 20, 2006 | 07:48 PM
  #248
93_hatch's Avatar
Default Re: (soldier604)
hey guys i recently picked up at jrsc for my d16z6 the sc has some miles on it so i thought i would rebuild it before i put it on. where can i find all the bearing and seals that need to be replaced beside jackson? also is there any benfit to porting the blower or should i just smooth the edges and weld the holes next to the triangle?
thanks for any info u guys got since there isnt much out there
Old Oct 20, 2006 | 10:11 PM
  #249
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soldier604 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of opinions you guys have on puting a jrsc on the stock d16y7. im aiming at about 150whp </TD></TR></TABLE>
look at the STOCK dyno graph that i posted earlier of the D16y7.
i'm sure you can make 150whp with minimal work.
Old Oct 20, 2006 | 10:16 PM
  #250
Default Re: (93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">is there any benfit to porting the blower or should i just smooth the edges and weld the holes next to the triangle?
thanks for any info u guys got since there isnt much out there</TD></TR></TABLE>
porting the blower will reduce your boost levels, but it also decreases your temps... so it kinda cancels eachother out. BUT, but but..... listen....
but you can add more boost, and the blower will be running at cooler levels than if it wasnt ported. so its a win/win.
welding the holes will make the blower louder. which, of course is way more bad ***!!!
read up on this thread...... so much reading, but so much info.
https://honda-tech.com/zerothread?id=1214810
