(non honda) oil return
sup guys,
i am working on a car which has a very short oil pan. the engine itself is conteins some of the oil,
the turbo itself sits way above the oil level.
can i make the drain placement under the ol level?
i know that VW 20vt engine has the return below the oil level.
thanks
thanks
Re: (non honda) oil return
I'm sure you can. Stealthmode oil lines did a video a while back on a Honda with a drain return coming back into the pan at the bottom. With the proper feed/restricter it shouldn't be a problem. but I've seen people weld s return Bing in the side of blocks b4 when things like this come up. It was on a spec-v sentra and it worked well.
D16y8_619
09-08-2006 09:05 PM
