newest uberdata released
Old Nov 4, 2003 | 11:15 AM
  #776
baphomet's Avatar
Default Re: (p3s7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3s7 &raquo;</TD></TR><TR><TD CLASS="quote">the worry for me is the ignition timing, could someone suggest a sort of baseline to retard from since the map is already pretty retarded for my engine, it's an issue because I haven't seen any concrete evidence of anyone doing it, or anyone talking about it at least in this thread or any really on the pgmfi forum for that matter.</TD></TR></TABLE>
Can't you open the p13 file in another editor and copy the timing like I did?
Old Nov 4, 2003 | 01:21 PM
  #777
p3s7's Avatar
Default Re: (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">
Can't you open the p13 file in another editor and copy the timing like I did?</TD></TR></TABLE>
hmm well don't I feel like an idiot now sorry, what other editors do you suggest/use?
EDIT: d/l'd CROME and can't find a copy that doesn't need a password to be unzipped, none of the places that posted it have the password in the post or even make any mention of it...? anyone have a copy I can download off their site or email to me? It seems like this is the only other rom editor people actually use in the real world besides uberdata...my question is how they ever got to it with this damn password?
Modified by p3s7 at 5:03 PM 11/4/2003
Old Nov 4, 2003 | 02:12 PM
  #778
PHiZ's Avatar
Default Re: (p3s7)
Because we're not dipshits. And there are at least 5 or 6 other editors that ppl use besides these two.
-PHiZ
Old Nov 4, 2003 | 02:42 PM
  #779
rjardy's Avatar
Default Re: (p3s7)
Modified by p3s7 at 5:03 PM 11/4/2003</TD></TR></TABLE>
Read PGMFI.ORG, educate yourself. The password will slap you in the face....
Rob
Old Nov 4, 2003 | 04:14 PM
  #780
T-RO's Avatar
try reading the Crome section of PGMFI, you cant miss it.
http://www.pgmfi.org/phorum/list.php?f=64
Old Nov 4, 2003 | 05:23 PM
  #781
p3s7's Avatar
OK, so I'm a dumbass and didnt use the search feature but I cannot get any of these p13 roms to open in any editor available on pgmfi.org, if you can get one that works, please let me know...here's the ones I have.
http://www.wwwyatt.com/roms/
BTW if anyone needs webspace to host something in relation to this let me know, I have quite a bit.
Old Nov 4, 2003 | 09:46 PM
  #782
Mr. Softee's Avatar
Default Re: (p3s7)
i need a new power supply where did everyone get theirs?
im looking at using this:
http://cgi.ebay.com/ws/eBayISA...39980
just cut the end off and use 2 plugs i have
sam
Old Nov 4, 2003 | 11:10 PM
  #783
ndogg's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">2 important questions:
1) does uberdata run off these maps at all times or does the ecu still go to closed loop?
2) what is the highest value you can put in a fuel table before you max out your duty cycle?</TD></TR></TABLE>
someone knows this!
Old Nov 4, 2003 | 11:56 PM
  #784
rjardy's Avatar
Default Re: (ndogg)
#1 I dont know
#2 depends on your injectors..
Rob
Old Nov 5, 2003 | 03:33 AM
  #785
ndogg's Avatar
Default Re: (rjardy)
how can it depend on the injectors? aren't the numbers in the fuel map basically the injector pulsewidth? the higher the number, the longer the injector stays open. so shouldn't there be a number that is the maximum injector pulsewidth (100% duty cycle)? why would it make a difference what injector your using, duty cycle is dependent on pulswidth (timeOn/totalTime). am i missing something?
if so, then tell me for dsm 450's please.
Old Nov 5, 2003 | 07:40 AM
  #786
raene's Avatar
Default Re: (ndogg)
Yeah, I believe max pulsewidth is a function of rpm rather than injector size. I think there was a thread a while back in this forum that showed a small tool that displayed your injector pulsewidth for every 10 percentage points, something you could install. Other than that I'm sure there's a way to tell, have to think about it though... I assume you convert rpm to max pulsewidth by noting how long it takes the engine to spin through the 'suck' phase of its cycle at a given rpm. Holding the injector open past that would just mean you're spraying fuel at the closed intake valve.
Old Nov 5, 2003 | 08:00 AM
  #787
omahaturbocivic's Avatar
Default Re: (ndogg)
#1 Closed loop works like normal, it will fine tune your vaccuum maps on its own. Although some of my eariler maps ran like crap at first even the bad ones would run decent in vaccuum after a few minutes of driving, untill you hit 0psi and it falls on its face .
#2 This was in blakes FAQ on the first page of this thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAQ &raquo;</TD></TR><TR><TD CLASS="quote">
On the fuel maps, the values dont mean anything special. All you need to know
is, the higher the #, the more fuel you get. Injectors start to max out around 800.
Old Nov 6, 2003 | 01:53 AM
  #788
swlabhot's Avatar
Default Re: (omahaturbocivic)
What is the appropriate ECU and bin can I use for EDM 98' ITR? P72 and stock GSR bin? Judging from users here I would have to disble the knock sensor to keep CEL away, correct?
Instead of the 74HC373 chip, can I use 74HC373N (with the N) instead or are they basically the same?
Modified by swlabhot at 11:46 AM 11/6/2003
Old Nov 6, 2003 | 02:51 AM
  #789
rjardy's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">how can it depend on the injectors? aren't the numbers in the fuel map basically the injector pulsewidth? the higher the number, the longer the injector stays open. so shouldn't there be a number that is the maximum injector pulsewidth (100% duty cycle)? why would it make a difference what injector your using, duty cycle is dependent on pulswidth (timeOn/totalTime). am i missing something?
if so, then tell me for dsm 450's please.</TD></TR></TABLE>
if the value maxed out the injector, would not the injector be the limiting factor?
Rob
Old Nov 6, 2003 | 06:52 AM
  #790
JDubya's Avatar
I need a power supply for my Batronix. Someone point me in the right direction...
Old Nov 6, 2003 | 07:56 AM
  #791
Joseph Davis's Avatar
Default Re: (ALL MOTOR LS)
Any cheap *** 12 volt wall PS will spike to ~18 volts with no load... a chip burner is about as close to no load as you can get.
I suggest reading the Batronix FAQ, it covers this.
Old Nov 6, 2003 | 08:02 AM
  #792
falcongsr's Avatar
What is this crap?
Default Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">
the N designation has nothing to do with the electrical characteristics of the chip. In this case, that last character identifies the package type. N means plastic DIP package.
so yes. its identical, and N is the correct package you need.
Old Nov 6, 2003 | 08:11 AM
  #793
swlabhot's Avatar
Default Re: (falconGSR)
Thx for clarifying that up
Old Nov 6, 2003 | 03:16 PM
  #794
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">
Rob</TD></TR></TABLE>
the injector would be the limiting factor yes. but if you just swapped in bigger injectors, using the same fuel value should max out those too. the difference is you can lean it out since you have bigger injectors. but the KEY is that the same fuel value in the map will max out all injectors at the same time.
Old Nov 6, 2003 | 03:37 PM
  #795
raene's Avatar
Default Re: (ndogg)
Yeah, the value is duration, not amount of fuel injected. Bigger injectors means you need to decrease the duration if you've maxed the stock ones out.
I'm going to reread the FAQ now...
Old Nov 6, 2003 | 05:31 PM
  #796
ndogg's Avatar
Default Re: (raene)
so who knows when uberdata will support datalogging?
Old Nov 6, 2003 | 06:17 PM
  #797
falcongsr's Avatar
What is this crap?
Default Re: (toxicshit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote">
int269stock.bin
this is a p72 JDM integra b18c4 dohc vtec Bin.
is has almoste all sensors dissabled,
YOU STILL NEED TO DISSABLE KNOCK I JUST SAW...
when im right FalconGSR uses this one !
Greetz Erwin
Modified by toxicshit at 10:55 PM 10/30/2003</TD></TR></TABLE>
so, when i look at the JDM P72 bin, it looks NOTHING like the UDSM bin around location 5467, and in BOTH bins this location = FF.
so how do we disable knock in a JDM p72 bin? I have a feeling its not the same location in the JDM bin. anyone try it or know the correct location to change?
Thanks,
JOe
if this doesnt work, i will be taking a USDM p72 map and disabling the PA sensor, the knock sensor and the injector test circuit. only the PA sensor hasnt been documented yet, but with luck i will figure it out.
also, since i am using a wideband and i dont have a stock o2 sensor, i hope to find the o2 sensor heater code and disable it also.
i am hoping my EDM P28 ECU has the ELD circuitry otherwise i'll have to find that too.
Old Nov 6, 2003 | 07:20 PM
  #798
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks,
JOe
i am hoping my EDM P28 ECU has the ELD circuitry otherwise i'll have to find that too. </TD></TR></TABLE>
toxicshit sent me one with knock disabled, and it ran great. I say ran because I think my faulty iat sensor is putting the jdm map in limp mode. It throws a code on obd2 and runs like ****. On the map I put b16 values in (from a usdm p30), with crome, and adjusted scalars it just runs like **** but no code - weird because I put the values in the jdm bin.
Anyway if you want it I'll send it to you. BTW, here is the difference:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Search for differences
1. F:\Programs\CROME\Int269stocknoknock.bin: 32.768 bytes
2. F:\Programs\CROME\Int269stock.bin: 32.768 bytes
Offsets: hexadec.
5467:00FF
1 difference(s) found.</TD></TR></TABLE>
here is my issue.
Old Nov 6, 2003 | 08:50 PM
  #799
PHiZ's Avatar
JDM P72
Knock sensor: 0x5467 00 disable
PA sensor: 0x5469 00 disable
ELD: 0x5471 FF disable
let me know if this works for ya.
-PHiZ
Old Nov 7, 2003 | 03:19 AM
  #800
toxicshit's Avatar
thats my winhex report
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by report.txt &raquo;</TD></TR><TR><TD CLASS="quote">
Offsets: hexadec.
5467:00FF
@phiz & @slashdevnull & @flaconGSR: PA is already disabled on the jdm integra 269 rom that ive send to slashdev null !! and ive cecked it again
this is what it looks like :
1. F:\Programs\CROME\slashdevnullalloff.bin: 32.768 bytes
2. F:\Programs\CROME\slashdevnullallon.bin: 32.768 bytes
Offsets: hexadec.
5467: 00 FF
5469: 00 FF
5471: FF 00
3 difference(s) found.
Greetz Erwin..
