newest uberdata released
Old Oct 31, 2003 | 10:41 AM
  #726
Darin D.'s Avatar
Default Re: (omahaturbocivic)
thats good to hear...hopefully the new version with 3 bar support is coming out soon, i'd like to try it.
Old Oct 31, 2003 | 11:04 AM
  #727
baphomet's Avatar
Default Re: (Willis)
okay, I got a usdm stock p30 map and transfered the timing and fuel settings into a jdm p72 bin with knock disabled - would someone like to double check it before I go ahead and run it?
I have no place to host it but I will email it to whoever wants it or can host it - as long as someone double checks it first.
Old Oct 31, 2003 | 11:42 AM
  #728
Mr. Softee's Avatar
Default Re: (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">Do you think I should just run the p72 map and fix the idle? The car seems to pull strong with it (just butt dyno though) Do you think the fuel and timing will be okay? I am more worried about the timing, as I have a wideband that I will hook up and make some passes with.
I am kind of worried about the p30 ermbaseline.
EDIT: I want to make sure the timing is correct because I will spray niitrous on the engine soon. (I don't have my turbo yet - I will use uberdata to pull timing in the upper vac area for nitrous)</TD></TR></TABLE>
just pull timing in the upper area if you are worried. worst case you lose a few hp... but who cares as long as your motor lasts.
Old Oct 31, 2003 | 11:43 AM
  #729
omahaturbocivic's Avatar
Default Re: (Quade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">U weren't really using that 3bar sensor setup at 12 psi..... were u?</TD></TR></TABLE>
Well I was over 10.65 or whatever the exact number the stock quits at. The main part of making a 3 bar work when designing a rom editor is not just making it work above 1 bar of boost, its making it work right altogether since the ouput votage is totally different and needs to rescaled for the whole fuel map. Since it works right in vaccum and the boost levels im at now, odds are the small portion of the fuel map that I have not ventured into yet will be fine as well. In any event ill know within the next week after the fuel pump is swapped and the boost gets turned up even higher. Ill try and post dyno results after I go to the dyno as well.
  #730
Mr. Softee's Avatar
Default Re: (Quade)
um, what
Old Oct 31, 2003 | 11:51 AM
  #731
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">I was comparing the jdm p72 bin with the p30_ermbaseline.bin because I have a b16a2. I was going to copy the fuel and timing maps from the p30_baseline to the jdm p72 bin (since I have a edm ecu) but it looks as though the p30 used more fuel than the jdm p72. Is this right? The timing seems more advanced also.</TD></TR></TABLE>
The P30 maps are inferred over from USDM code. From what I remember, there was less fuel in the P30 than P72 .bin, although it was actually close near WOT. The ignition was similar but not identical... ~42 degrees advance in midrange part throttle is what you should have for either P72 or P30 maps.
Old Oct 31, 2003 | 11:56 AM
  #732
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">okay, I got a usdm stock p30 map and transfered the timing and fuel settings into a jdm p72 bin with knock disabled - would someone like to double check it before I go ahead and run it?
I have no place to host it but I will email it to whoever wants it or can host it - as long as someone double checks it first.</TD></TR></TABLE>
I was comparing the p30ermbasline with the one I made, and the p30erm baseline is richer but timing is pretty close.
Anyway, I think I will use the b18c4 map and pull timing in the upper end like you suggested. Unless someone cares to look at my jdmp72withp30maps bin.
Old Oct 31, 2003 | 12:37 PM
  #733
baphomet's Avatar
I compared the jdm p72 map with p30 values I made to the stock jdm p72. The one I made has timing advanced more than the p72. Hmm, wish I knew more about this
Old Oct 31, 2003 | 01:32 PM
  #734
ndogg's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
How the IABs are actuated is an OBD specific thing, not market origin thing, or so I thought.</TD></TR></TABLE>
USDM OBD2 == positive trigger
USDM OBD1 == negative trigger
JDM OBD1 == positive trigger
another question: when using the FTL, is the ecu just cutting the injectors? isn't this going to lead to detonation?
Old Oct 31, 2003 | 01:39 PM
  #735
raene's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
another question: when using the FTL, is the ecu just cutting the injectors? isn't this going to lead to detonation?</TD></TR></TABLE>
Running lean doesn't cause detonation, the heat in the chambers causes detonation. Running lean causes the temps to rise drastically, to the point where preignition occurs... with no fuel in the chambers, you can't possibly detonate.
IMO and AFAIK of course
Old Oct 31, 2003 | 02:16 PM
  #736
ndogg's Avatar
Default Re: (raene)
so do people think this is safe? also, if you retard and dump fuel for your FTL, won't this kinda screw up your power band at that area when just driving around?
these guys dont think its a great idea
https://honda-tech.com/zerothread?id=566467
Modified by ndogg at 3:29 PM 10/31/2003
Old Oct 31, 2003 | 02:31 PM
  #737
SOUNDEFFECTS's Avatar
Default Re: (ndogg)
P30 stock runs more ignition advance then a P72 does stock. P72 runs more fuel then a P30 does stock. I can be more detailed if any buddy cares.
Old Oct 31, 2003 | 03:07 PM
  #738
raene's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">so do people think this is safe? also, if you retard and dump fuel for your FTL, won't this kinda screw up your power band at that area when just driving around?
https://honda-tech.com/zerothread?id=566467</TD></TR></TABLE>
I don't think it's a great idea either I think it's more intended for drag-only cars.
Old Oct 31, 2003 | 03:11 PM
  #739
marlborocars's Avatar
FOR slashDEVslashNULL.
The reason for the P30 been more rich is that the fuel presure on the b16 is 43psi and for P72 b18c is 52psi
Old Oct 31, 2003 | 03:29 PM
  #740
baphomet's Avatar
Default Re: (marlborocars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marlborocars &raquo;</TD></TR><TR><TD CLASS="quote">FOR slashDEVslashNULL.
The reason for the P30 been more rich is that the fuel presure on the b16 is 43psi and for P72 b18c is 52psi</TD></TR></TABLE>
Ah, that makes sense. <FONT SIZE="2"><FONT COLOR="red"> But here is what I just noticed, the stock p30 is leaner than the jdm p72 BUT the p30 erm baseline is richer than both</FONT></FONT>
I have another question - I used crome to copy and paste from a stock usdmp30 to a jdm p72, some of the rpm points didn't exactly match up, like at 5773 I put values from 6019 and so on, will this be okay?
Old Oct 31, 2003 | 03:55 PM
  #741
red_sir's Avatar
I have another question - I used crome to copy and paste from a stock usdmp30 to a jdm p72, some of the rpm points didn't exactly match up, like at 5773 I put values from 6019 and so on, will this be okay?</TD></TR></TABLE>
If you're using Crome, why don't you copy the USDM P30 maps to a JDM P30 bin? This way all the rpm and map points match up and you can add boost straight to the JDM P30 map with Crome. But only problem is you can't edit it with Uberdata afterwards.
Old Oct 31, 2003 | 05:04 PM
  #742
baphomet's Avatar
Default Re: (red_sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_sir &raquo;</TD></TR><TR><TD CLASS="quote">
If you're using Crome, why don't you copy the USDM P30 maps to a JDM P30 bin? This way all the rpm and map points match up and you can add boost straight to the JDM P30 map with Crome. But only problem is you can't edit it with Uberdata afterwards. </TD></TR></TABLE>
Yeah I could do that in theory....in theory communism works........in theory.............
Seriously though, I know, I just want to use uberdata. (I'll keep my opinions to myself) I only used crome because I didn't want to manually edit the bins. Do you know if the jdm p30 has baro and injector test disabled - I guess it doesn't matter because I could use a edm p30 map.
  #743
In CROME you can change the RPM and MAP scalars to a match or a close one.
Old Oct 31, 2003 | 05:08 PM
  #744
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marlborocars &raquo;</TD></TR><TR><TD CLASS="quote">In CROME you can change the RPM and MAP scalars to a match or a close one.
hmm maybe I'll go play with it
Old Oct 31, 2003 | 05:30 PM
  #745
ndogg's Avatar
when running uberdata, are you in open loop all the time?
Old Oct 31, 2003 | 07:39 PM
  #746
Default Re: (ndogg)
Fuel cut isn't as dangerous as some people think. Road Race Engineering has an excellent write up on the subject, as well as a traction control unit that operates off of just such a principle.
Old Nov 1, 2003 | 08:34 AM
  #747
baphomet's Avatar
</TD></TR></TABLE>I just tried it but it doesn't seem to apply the settings - Is there something I am missing?
Old Nov 1, 2003 | 08:45 AM
  #748
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">I just tried it but it doesn't seem to apply the settings - Is there something I am missing?</TD></TR></TABLE>
It is capable of working, but it's implementation is buggy. It's consistent, but there is a flaw in the UI.
Figure it out.
-PHiZ
Old Nov 1, 2003 | 11:40 AM
  #749
hybridb18's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">when running uberdata, are you in open loop all the time? </TD></TR></TABLE>
Old Nov 1, 2003 | 12:59 PM
  #750
In tool box, open points adjustment, change col and row one at a time and hit close and the scalars are going to change.
DONT TOUCH THE FIRST AND LAST OF COL AND ROW IF YOU WANT YOUR CAR TO RUN.
