newest uberdata released
Old Oct 6, 2003 | 11:19 AM
  #476
Mr. Softee's Avatar
Default Re: USDM ecus only? (Quade)
p28s are like $50 if you shop around. Even less often.
Old Oct 6, 2003 | 12:43 PM
  #477
djmatix's Avatar
no, it works on jdm ecus as well. I'm using it on a JDM P30 ecu with a JDM p72 turbo rom.
Old Oct 6, 2003 | 01:05 PM
  #478
PHiZ's Avatar
Default Re: USDM ecus only? (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">p28s are like $50 if you shop around. Even less often.</TD></TR></TABLE>
BUUUUULLLLSSSSHHHHIIIITTTTT
-PHiZ
Old Oct 6, 2003 | 01:40 PM
  #479
raene's Avatar
Default Re: USDM ecus only? (PHiZ)
Unfortunately I agree They've gotten rarer lately... the cheapest I can find is $125 for an A/T version (CDN) about $85 USD.
Old Oct 6, 2003 | 03:48 PM
  #480
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
I got one for $20 once just gotta find the junkyards that arent honda specific who just wanna get rid of the stuff
Old Oct 6, 2003 | 04:05 PM
  #481
civperc's Avatar
Default Re: USDM ecus only? (greekspeed)
getting my P06 already socketed/soldered to accept a 28 pin chip, for 100
Old Oct 6, 2003 | 05:57 PM
  #482
FyReo3's Avatar
Got a P28 for $45. But I have an advantage over most of you, junkyards around here have no clue.
Old Oct 6, 2003 | 08:03 PM
  #483
DA-MAX's Avatar
I just have to add that this is a great thread...I've read over all 17 pages about 2 -3 times and I've learned a **** load...looks like OBDI swap and Uberdata is the way for me!
just wanna confirm..for a 90-91 OBD0 Integra I'm looking for an OBD1 PR4 from a 92-93 or a OBD1 P74 from a 94+ Integra?? Thanks for any help
EDIT: just read greekspeeds post..could someone elaborate more on that about the OBD1 PR4 and P74 differences(if any)??
Old Oct 6, 2003 | 09:10 PM
  #484
R6Elmo's Avatar
I have a turbo LS. I chipped the PR4 and the P75 with the same chip. P75 ran better. It was as if my PR4 wasn't reading the rom or something. ANd yes, i know how to chip ecus.
Danny
Old Oct 6, 2003 | 09:21 PM
  #485
PHiZ's Avatar
Default Re: USDM ecus only? (R6Elmo)
Ok, certain families of ECUs will run certain families of code.
Kinda like your PC won't run mackintosh software. kinda.
Here is what I know
P28, P30, P05, P06 are the same family, and can run cross platform code.
P72, P75, P73, are teh same family and will run the same code.
I also have it on good authority that P75/P72/P73 code will run on P28/P06/P30 ecus.
Anyone feel free to elaborate.
Raene, sorry to treat you like a noob, but I'm tired of ppl coming off like they need hand-holding, s-fly had the same info as you, and he was able to come up with an answer... but, yeah, those images are shitty to read.
-PHiZ
Old Oct 6, 2003 | 09:32 PM
  #486
falcongsr's Avatar
What is this crap?
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Wow... that looks hella easy, and I'm willing to bet the guy would let the auto ECU go for much cheaper than the manual. There are no other differences than those jumpers? I wish the picture was bigger - I can't see anything on that one... and the board shown which is supposed P28 looks nothing like Katman's pic of a P28 ECU </TD></TR></TABLE>
[edited] i thought this was a pic of a jdm ecu i am not sure antmore still learning! [/edited]. I will be trying to figure out how to convert one of these to manual next week. hopefully its as straightforward as it is on the USDM ECUs
Old Oct 6, 2003 | 09:33 PM
  #487
civperc's Avatar
Default Re: (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
yeah Katmans pic is of a JSM p28 ECU. I will be trying to figure out how to convert one of these to manual next week. hopefully its as straightforward as it is on the USDM ECUs</TD></TR></TABLE>
maybe you could let us know how that goes
Old Oct 6, 2003 | 11:46 PM
  #488
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">I have a turbo LS. I chipped the PR4 and the P75 with the same chip. P75 ran better. It was as if my PR4 wasn't reading the rom or something. ANd yes, i know how to chip ecus.
Danny</TD></TR></TABLE>
if your ecu wasnt reading the rom you would go into limp mode. it would be quite obvious.
Old Oct 6, 2003 | 11:48 PM
  #489
greekspeed's Avatar
if your ecu wasnt reading the rom you would go into limp mode. it would be quite obvious.</TD></TR></TABLE>
hmm well maybe it simply did not work as well?
Old Oct 6, 2003 | 11:50 PM
  #490
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed &raquo;</TD></TR><TR><TD CLASS="quote">
hmm well maybe it simply did not work as well?</TD></TR></TABLE>
Sounds highly doubtful from your results. Sounds like it was in your head.
You must understand, its not as if the signals given to the ecu are going to change, nor is the way the ecu going to change the way it interprets a signal in a subtle way as you are descrbing. If its not in limp mode or reasonably out of whack, its in your head imho.
Old Oct 6, 2003 | 11:55 PM
  #491
greekspeed's Avatar
You must understand, its not as if the signals given to the ecu are going to change, nor is the way the ecu going to change the way it interprets a signal in a subtle way as you are descrbing. If its not in limp mode or reasonably out of whack, its in your head imho.</TD></TR></TABLE>
uhh this isnt my car its r6's
Old Oct 7, 2003 | 05:29 AM
  #492
Quade's Avatar
Default Re: USDM ecus only? (djmatix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">no, it works on jdm ecus as well. I'm using it on a JDM P30 ecu with a JDM p72 turbo rom.</TD></TR></TABLE>
Where did you get that rom? Mind sending me the bin? Let me know. I have access to a JDM P72 but I can't even find a stock JDM P72 rom. Been searching.
Old Oct 7, 2003 | 06:04 AM
  #493
DA-MAX's Avatar
Default Re: (94goldjungsr)
as far a a romulator goes, its not really real-time, just skips chip removal/replacement right? so you would still need the burner in this case to link to the romulator? I was thinking the romulator wen't straight to te laptop(sorry if this is "noobish") I was considering this, but it doesn't seem worth it when you can just pop out the ECU, reburn, "re-chip" and pop it back in
define realtime.
if you want emulation you can use an emulator JUST like hondata does. if you look at the emulator hondata uses, its not like they make it themselves or it has any dependence on any specific element of the Hondata control box or something. All it does is place a cord from your burner into the chip location so you can burn on the fly without having to take chips in and out. I think its pretty superfluous for $200~ that they cost. But... if you wanan say you can burn on the fly, go for it! Its useless on the dyno though and when doing street tuning imho, because you should be cooling your car down between runs somewhat
sam</TD></TR></TABLE>
Old Oct 7, 2003 | 08:08 AM
  #494
raene's Avatar
Nice - keep us posted The wrecking yards around here are very Honda-wise since there's so many Honda drivers, but they don't seem to know the value of the automatic P28s the way they do the manuals (the cheapest manual I could find was $195... and he wouldn't budge on the price). Perhaps this could be a far better option than a manual P28 for people like me.
PHiZ, no worries I don't mind digging in and learning but I'd like to know where to dig, y'know?
Old Oct 7, 2003 | 09:07 AM
  #495
Mr. Softee's Avatar
Default Re: (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">as far a a romulator goes, its not really real-time, just skips chip removal/replacement right? so you would still need the burner in this case to link to the romulator? I was thinking the romulator wen't straight to te laptop(sorry if this is "noobish") I was considering this, but it doesn't seem worth it when you can just pop out the ECU, reburn, "re-chip" and pop it back in
you still need the chip burner. the romulator doesnt go straight to the laptop. but it is pretty much real time.
sam
Old Oct 7, 2003 | 09:15 AM
  #496
tec_wiz's Avatar
where would I find an emulator that I could use? any good ones that you guys use?
Old Oct 7, 2003 | 09:22 AM
  #497
Mr. Softee's Avatar
Default Re: (tec_wiz)
i was just looking at this one:
http://www.hondata.com/romulator.html
on the hondata website.
its a little different than the old one they were using. i have never used this one. it looks pretty similar thogh.
Old Oct 7, 2003 | 10:18 AM
  #498
DA-MAX's Avatar
heres the actual site for that romulator---&gt;
http://www.xtronics.com/memory/romutator.htm
I htink they also have a programmer too, for $150(but seems you can find Batronix for much less)
oh and 94goldjungsr, thanks for clearing that up
Old Oct 7, 2003 | 10:40 AM
  #499
00b18b's Avatar
just wonder is the pocket romulator the best and only one we should use? Is there a benefit using this over another type .....
http://xoomer.virgilio.it/lorgler/ebyter.htm
http://www.futurlec.com/EPROMEmulator.shtml
Old Oct 7, 2003 | 10:43 AM
  #500
falcongsr's Avatar
What is this crap?
Default Re: (raene)
PHiZ, no worries I don't mind digging in and learning but I'd like to know where to dig, y'know? </TD></TR></TABLE>
i havent come up with a definitive answer on how to convert a JDM p28 auto ecu to manual yet. if anybody knows, please share it here.
