newest uberdata released
Old Oct 29, 2003 | 02:38 PM
  #676
rjardy's Avatar
Default Re: (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">
Here is how I did my setup...
Open Map
Ignition Retard 1 degree (Hit Apply)
Set Fuel Efficiency to 120% (Hit apply)
set my rev limiters, FTL, vtec, etc...
set TPS Enrichment using [(240/440)*100]+5 which brings me to 59.54... Putting 59 into the TPS Enrichment... This left the car running and boosting, but PIG rich...
I then made another map the same way, only went into the Fuel Low and Fuel Hi, went down to the MATH table, punched in 80%, selected the entire grid, and hit apply. Did that in both the low & hi table... That puts me at 440cc approximate fuel minus 20%, correct? Because this still left me PIG rich.
Also, everytime I redo a map, I start from scratch because of the extrapolation process... As where if I take the OEM Figures, subtract 20% from them, then its too rich, then I take another 10% out, and its not 10% from stock, but 10% from the 80%, which is a different extraction number... Understand what i mean? </TD></TR></TABLE>
Im thinking you didnt set up your map corectly, have you read the FAQ and FOLLOWED THEM? 440cc injectors or 450? for 450 you will need to add the correct value of58 into the multiplication block on the fuel map and interpolate. select the entire map and do this. Sounds like you are still setup for stock injectors.
Rob
Old Oct 29, 2003 | 02:40 PM
  #677
Mr. Softee's Avatar
Default Re: (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">
Rob</TD></TR></TABLE>
so it seems. lol...
Old Oct 29, 2003 | 02:48 PM
  #678
rjardy's Avatar
Default Re: (94goldjungsr)
im not sure if thats sarcastic or not? I think that I am understanding this enough now, but when you say somethinglike that it makes me doubt what i think i know
Rob
Old Oct 29, 2003 | 02:50 PM
  #679
Mr. Softee's Avatar
no i agre with you im just blown away that he did that.
Old Oct 29, 2003 | 02:51 PM
  #680
ScrapinSi's Avatar
OOOOOHHHH&gt;.. Waiittt...&gt; I'm supposed to do the 240/newinjector*100+5 for BOTH the TPS Enrichment AND the fuel maps? I thought the TPS Enrichment adjusted the fuel maps! Am I thinking correctly now? So I need to set the Math Table to 59% and the TPS Enrichment to 59% right? And the fuel Enrichment to 120%?
Old Oct 29, 2003 | 02:55 PM
  #681
rjardy's Avatar
Yeah its all in the FAQ, you should have read them , it would have saved you allot of time. Make your adjustments, reburn, and let us know.
Rob
Old Oct 29, 2003 | 03:01 PM
  #682
rjardy's Avatar
yeah the TPS is not going to change the fuel MAP
Rob
Old Oct 29, 2003 | 03:16 PM
  #683
Mr. Softee's Avatar
btw its 240/450 you multiply the maps by, not 450/240 as i originally, extremely stupidly, posted.
Old Oct 29, 2003 | 03:26 PM
  #684
ScrapinSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">Yeah its all in the FAQ, you should have read them , it would have saved you allot of time. Make your adjustments, reburn, and let us know.
Rob </TD></TR></TABLE>
I did read the FAQ, I just didnt understand it correctly... I have read the FAQ AT LEAST 30 times... LOL... I read it everytime I make a map... i just wasn't looking at it correctly...
I was just bored, so I figured I would do this little writeup... How does this look to you guys? its a 500k word doc I made with screenshots... Is this correct?
http://members.aol.com/scrapin...a.doc
And anybody have any other Idea on my phantom check engine light? I'm gonna pull out my socket & 74hc373 chip this weekend and resolder it with a better grade of solder than I used...
Old Oct 29, 2003 | 03:27 PM
  #685
Mr. Softee's Avatar
are you in limp mode or is it just a solid CEL that drives normal. what ecu / what bin you using.
sam
Old Oct 29, 2003 | 03:28 PM
  #686
ScrapinSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">are you in limp mode or is it just a solid CEL that drives normal. what ecu / what bin you using.
sam</TD></TR></TABLE>
just a solid CEL, drives normal... P28 ECU, stockgsr.bin running on a b16a2 w/ obd2-obd1 Xover Harness in my 2000 Si.
Old Oct 29, 2003 | 03:39 PM
  #687
egmike's Avatar
I had same problem, it was looking for knock sensor... i am running d16z6 though so no knock for me
Old Oct 29, 2003 | 08:49 PM
  #688
B94Cast's Avatar
Default Anyone know
when we might get the Cold Crank Enrichment enabled?
edit: Or when we might be able to set open/closed loop threshold via vacuum/pressure reading?
Old Oct 29, 2003 | 09:51 PM
  #689
Mr. Softee's Avatar
just a solid CEL, drives normal... P28 ECU, stockgsr.bin running on a b16a2 w/ obd2-obd1 Xover Harness in my 2000 Si.</TD></TR></TABLE>
roger that, knock sensor is most likely what it is related to. ive only seen that happen to one persons ecu and i never got around to fixing it
Old Oct 30, 2003 | 12:32 AM
  #690
toxicshit's Avatar
Im Looking at it right now !!
Old Oct 30, 2003 | 01:17 AM
  #691
rjardy's Avatar
Default Re: (toxicshit)
I hate to be a dick but honestly, if you are having troubles creating the correct maps for YOUR setup, I dont think that you should be making tutorials on this. All the info anyone need to know is in the FAQ.
Just want to reiderate, im not trying to be a dick.
Rob
Old Oct 30, 2003 | 03:00 AM
  #692
T-RO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">I hate to be a dick but honestly, if you are having troubles creating the correct maps for YOUR setup, I dont think that you should be making tutorials on this. All the info anyone need to know is in the FAQ.
Shouldnt that be "reiterate"?
Just messin with ya man
Old Oct 30, 2003 | 04:03 AM
  #693
ScrapinSi's Avatar
I wasn't making it as a tutorial... I was making it as screenshots to verify that I was doing it correctly..&gt; If not, please correct me...
Also, since its the knock sensor, can I just go into the hex code, at location 5467, and change the FF to 00 to disable it? Would that fix it?
Old Oct 30, 2003 | 04:57 AM
  #694
toxicshit's Avatar
yes for a p72 base map you can raw hex edit 5467 from FFH to 00H
Also, since its the knock sensor, can I just go into the hex code, at location 5467, and change the FF to 00 to disable it? Would that fix it? </TD></TR></TABLE>
Old Oct 30, 2003 | 05:07 AM
  #695
ScrapinSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote">yes for a p72 base map you can raw hex edit 5467 from FFH to 00H
Just want to make sure here.... Just triple checking... This one, right? Line 5460, space 7.
Old Oct 30, 2003 | 05:22 AM
  #696
Joseph Davis's Avatar
Aww... someone knows how to use the compare function on WinHex. Toxic =
Old Oct 30, 2003 | 05:38 AM
  #697
ScrapinSi's Avatar
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Aww... someone knows how to use the compare function on WinHex. Toxic = </TD></TR></TABLE>
compare function?? I went into PocketProgrammer, loaded the bin, and clicked edit buffer...
Old Oct 30, 2003 | 05:51 AM
  #698
toxicshit's Avatar
thnx.... im a computer interface Technician.
so i write lots of stuff in 8051 and C++ so i also have to check my 8051 scripts in Hex some times
And like i said ScrappinSi change the FFH to 00H on location 5467
so if i see it correct in your jpg and that should do the trick
Greetz Erwin
Old Oct 30, 2003 | 06:32 AM
  #699
falcongsr's Avatar
What is this crap?
i'm an ultraedit *****
Old Oct 30, 2003 | 07:37 AM
  #700
ScrapinSi's Avatar
Default Re: (falconGSR)
UltraEdit? Is that a Hex Editor? Does anybody have a Complete p72 Hex Translation?
