newest uberdata released
Old Sep 26, 2003 | 10:29 PM
  #301
B94Cast's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (slashDEVslashNULL)
the programs are now available!
Old Sep 26, 2003 | 10:47 PM
  #302
toxicshit's Avatar
Default Re: Update on my Batronix programmer and some info (Overblown-Teg)
@ overblown-teg >you dont need the com port settings. you need the parallel port settings ( LTP1 )
Old Sep 26, 2003 | 10:56 PM
  #303
toxicshit's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (B94Cast)
i see, blake what kind of system requirements does the 800 x 600 version need to have ?? becaus i have this old black and white Laptop with a sloww *** proq ?
Old Sep 27, 2003 | 01:58 AM
  #304
toxicshit's Avatar
i can buy this one for a nice price, http://www.hod-electronics.nl/...3.PDF
Can i use it ?? it says so in the data sheet. but i just want to know for sure from all you honda gurus
Old Sep 27, 2003 | 07:52 AM
  #305
civperc's Avatar
Default Re: (toxicshit)
hmm, how much can you get that for? I like USB connectivity.
Old Sep 27, 2003 | 07:55 AM
  #306
Rakka's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (toxicshit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit &raquo;</TD></TR><TR><TD CLASS="quote">i see, blake what kind of system requirements does the 800 x 600 version need to have ?? becaus i have this old black and white Laptop with a sloww *** proq ?</TD></TR></TABLE>
Hmmm, it doesnt really use any cpu time, no real image either. My only concern is not being able to red he cell values over their background shading.
edit, the batronix usb burner is about $200 if that helps any
Old Sep 27, 2003 | 09:53 AM
  #307
Overblown-Teg's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (Rakka)
I found the printer MODE in setup. there is epp+ecp, output only and bi- directional. Which one of those would you guys say is right? Is that the correct section to be looking? I have a compaq with xp.
Old Sep 27, 2003 | 01:00 PM
  #308
civicguy's Avatar
how do i open the bin file,it says windows can not open this file,im using windows xp
Old Sep 27, 2003 | 01:03 PM
  #309
B94Cast's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (Overblown-Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">I found the printer MODE in setup. there is epp+ecp, output only and bi- directional. Which one of those would you guys say is right? Is that the correct section to be looking? I have a compaq with xp.</TD></TR></TABLE>
Yes, that is it. take it out of ECP/EPP Mode and set it to bidirectional!
Old Sep 27, 2003 | 01:21 PM
  #310
baphomet's Avatar
Default Re: (civicguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicguy &raquo;</TD></TR><TR><TD CLASS="quote">how do i open the bin file,it says windows can not open this file,im using windows xp</TD></TR></TABLE>
::sigh::
1. Launch uberdata (uberdata.exe) by double clicking on it.
2. Click 'I Agree'
3. Click 'File'
4. Click 'open'
5. Locate the desired .bin file.
6. Double Click it.
7. Read some books.
Old Sep 27, 2003 | 01:48 PM
  #311
SC94DB8's Avatar
Just curious... I modified the stock LS map for 450cc injectors, and entered a fuel average efficiency of 120%. Under the ignition tables, the timing is at -6.00 in all areas of boost.(same as the stock LS map) Does this seem correct, or should these values be something different?
Old Sep 27, 2003 | 02:43 PM
  #312
B94Cast's Avatar
Default Re: (greekspeed)
The stock honda sensor is good for up to 1 bar. So yes, if you are not boosting above that, the stock sensor will be fine. You dont need any check valves and all that junk...
Old Sep 27, 2003 | 02:45 PM
  #313
civcexcoupeblack's Avatar
you need either a 3 bar map sensor, or any of the methods you mentioned.
Old Sep 27, 2003 | 04:43 PM
  #314
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed &raquo;</TD></TR><TR><TD CLASS="quote">ok this might be a stupid question.......and if it is... i will get flamed........but hey at leased ill know the answer
lol
Old Sep 27, 2003 | 05:00 PM
  #315
Rakka's Avatar
Default Re: (SC94DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC94DB8 &raquo;</TD></TR><TR><TD CLASS="quote">
Just curious... I modified the stock LS map for 450cc injectors, and entered a fuel average efficiency of 120%. Under the ignition tables, the timing is at -6.00 in all areas of boost.(same as the stock LS map) Does this seem correct, or should these values be something different?</TD></TR></TABLE>
Read the faq, i am in a generous mood, and will tell you however. Click on the boost setting, set the boost ignition retard to 1.0 and click apply, this will populate the boost portion of the ignition map.
The stock map sensor can read ~11psi. Doesnt need checkvalves or anything, just a chipped ecu, larger injectors, and pressure in your intake manifold
Old Sep 27, 2003 | 05:08 PM
  #316
SC94DB8's Avatar
Default Re: (Rakka)
Sorry about that. When I clicked on the boost tab the ignition retard was preset at 1.0, I just didn't apply it. At first glance it looked like it was already done.
I thank you for your generous mood Rakka
Old Sep 27, 2003 | 05:47 PM
  #317
asianspeed's Avatar
uberdata sounds great and I will eventually go this route for my setup. However, I was curious what tuning methods people are using. Using an EGT guage and a wideband...how much timing do you advance or retard to reduce or increase EGT numbers by a certain temp or vice versa? Or how much fuel do you add or subtract to get from 9:1 to 12:1 ratio? I've never tuned a car so I'd rather stay away from guessing and checking and reburning chips and all of that junk....
Old Sep 27, 2003 | 06:04 PM
  #318
raene's Avatar
Default Re: (Rakka)
Why can't you change boost ignition retard to anything other than 1.0?
Old Sep 27, 2003 | 08:47 PM
  #319
civperc's Avatar
Default Re: (raene)
you can. type in like "0.80" and click apply, and it'll change the ignition map. it'll switch back to 1.0 in the typing field, but the changes to the map will stay.
Old Sep 27, 2003 | 10:47 PM
  #320
R6Elmo's Avatar
Default Re: (asianspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianspeed &raquo;</TD></TR><TR><TD CLASS="quote">Or how much fuel do you add or subtract to get from 9:1 to 12:1 ratio? I've never tuned a car so I'd rather stay away from guessing and checking and reburning chips and all of that junk....</TD></TR></TABLE>
I know you hate checking and having to reburn chips all the time, but it's something you'll probally have to do. It's hard to really guess, because if you overshoot, and run too lean = byebye motor.
It depends on your turbo,injectors, fuel, etc etc. On my car, about 10% fuel would get me around 1.0 lambda
Old Sep 28, 2003 | 12:26 AM
  #321
raene's Avatar
Default Re: (untensadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untensadude &raquo;</TD></TR><TR><TD CLASS="quote">you can. type in like "0.80" and click apply, and it'll change the ignition map. it'll switch back to 1.0 in the typing field, but the changes to the map will stay.</TD></TR></TABLE>
Ahh! Stupid me... never checked for field changes, just checked to see if the ignition retard value changed
Thanks!
Old Sep 28, 2003 | 03:49 AM
  #322
dabrown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianspeed &raquo;</TD></TR><TR><TD CLASS="quote">uberdata sounds great and I will eventually go this route for my setup. However, I was curious what tuning methods people are using. Using an EGT guage and a wideband...how much timing do you advance or retard to reduce or increase EGT numbers by a certain temp or vice versa? Or how much fuel do you add or subtract to get from 9:1 to 12:1 ratio? I've never tuned a car so I'd rather stay away from guessing and checking and reburning chips and all of that junk....</TD></TR></TABLE>
This is a good question, I would love to know the answer to this question. I am a little shocked that I do not see more tuners in this forum.. Then again this hurts the business. However if any tuners are reading this, please understand that some of us will still go to you for tuning. Uberdata is great for DIY's. For the rest we still prefer to drop the car by and let you do your thing..
Old Sep 28, 2003 | 03:54 AM
  #323
rjardy's Avatar
Default Re: (dabrown)
Unless you somehow get it 100% correct the first time, you will have to reburn a chip. Same thing happens with hondata. corections will need to be made.
Rob
Old Sep 28, 2003 | 06:15 AM
  #324
toxicshit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">hmm, how much can you get that for? I like USB connectivity.</TD></TR></TABLE>
i have called a local Electronics shop,
He will know it thuesday. so ill post the price when i know more.
Old Sep 28, 2003 | 07:53 AM
  #325
civperc's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks! </TD></TR></TABLE>
no problemo
