newest uberdata released
Old Sep 26, 2003 | 06:47 AM
  #276
T-RO's Avatar
Questions about Boost Controller & VTEC features:
1) Is the Boost Controller feature enabled? If I enter 4 low and 8 high will it work? Do you have to do anything else to the turbo or car to get Boost Control feature working?
2) With the VTEC feature, what is ment by the Disable RPM? Is that when your car goes Out of Vtec while decelerating?
Old Sep 26, 2003 | 07:09 AM
  #277
94lsboost's Avatar
OK i see the boost controller feature is disabled, does that mean if i get the premium version VIA contributing to the cause, it'll be enabled there? And in the version where you can use the boost controller feature, how does it control your boost? I really dont understand that....?
Old Sep 26, 2003 | 07:22 AM
  #278
R6Elmo's Avatar
Default Re: (94lsboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost &raquo;</TD></TR><TR><TD CLASS="quote">OK i see the boost controller feature is disabled, does that mean if i get the premium version VIA contributing to the cause, it'll be enabled there? And in the version where you can use the boost controller feature, how does it control your boost? I really dont understand that....?</TD></TR></TABLE>
I don't think this would actually control your boost. You still need to purchase a boost controller or solenoid of some sort. I dnt' understand it completely. But just chipping an ecu doesn't control boost, you stll need another mechanical assembly in order to control teh wastegate open/closing.
Old Sep 26, 2003 | 07:24 AM
  #279
boosted hybrid's Avatar
You use the pinouts from the ecu to control a dual stage manual boost controller. You would have to find out which pinouts are energized, then wire the power into the dual stage boost controller so it would switch from low to high boost according to the setting in uberdata.
Old Sep 26, 2003 | 07:31 AM
  #280
raene's Avatar
Default Re: (boosted hybrid)
I would assume since the A/C is disabled with the boost control enabled checking the A/C pinouts for action when boost control becomes enabled would be a pretty wise move
Old Sep 26, 2003 | 08:15 AM
  #281
B94Cast's Avatar
Default Re: Update on my Batronix programmer and some info (untensadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untensadude &raquo;</TD></TR><TR><TD CLASS="quote">which burner are you using? batronix?</TD></TR></TABLE>
Yes, ver. 3.3
Overblown-Teg - Let me know how it turns out! What version of the batronix are you using? It is silkscreened on the PCB. If you are using 3.2, there is a write-up on how to convert to 3.3.
  #282
fox297's Avatar
Can someone please tell me how to erase the 29c256 chip. Can I just over write the old program with the new one?
*Finding this post is like digging gold off the internet!
Old Sep 26, 2003 | 08:21 AM
  #283
B94Cast's Avatar
Default Re: (fox297)
The erasing of this memeory IC is not necessary because it can be over programmed wihtout erasing them first.
Cant wait until my 29C comes in!
Old Sep 26, 2003 | 08:24 AM
  #284
Overblown-Teg's Avatar
Default Re: (B94Cast)
I have v3.3 and the newest software.
Old Sep 26, 2003 | 08:52 AM
  #285
Burke's Avatar
Banned
Default Re: (Overblown-Teg)
any body know how to use launch control???? I cant seem to figure it out???
Thanks
Burke
EDIT - im a retard! just floor the ****
sucks on my street tires, just puts them up i smoke, but it should work well on slicks
Modified by Burke at 7:43 AM 9/27/2003
Old Sep 26, 2003 | 09:54 AM
  #286
Mr. Softee's Avatar
Default Re: (Burke)
oh **** yea thats right... i had major errors at first too until i used a new cable. i bought a cable brand new from Fry's and it ended up not working... i found osme old one around the house and it worked. no idea why.
Old Sep 26, 2003 | 10:03 AM
  #287
raene's Avatar
Default Re: (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">any body know how to use launch control???? I cant seem to figure it out???
Thanks
Burke</TD></TR></TABLE>
Do you not just set launch control engagement point in the tab and that's it? Is that not working for you?
Old Sep 26, 2003 | 10:19 AM
  #288
LoSt is BlaCk's Avatar
Default Re: (raene)
great post!
Old Sep 26, 2003 | 10:23 AM
  #289
Mr. Softee's Avatar
Default Re: (Chpt1onBOOST)
i cant believ eyou guys are catching on so late, i already tuned my Ls on uberdata for 255whp @ 10psi i cant wait to see ya'll dyno numbers.
when you tune just make sure you start out real rich and then back off. Dont start lean and add fuel.
also, take out like 10% fuel for every +/- 1 a/f ratio and dial in for 11.5:1-12:1 from 3k on. It can be leaner before that.. for timing dont go below 0.5 degree per # taken out, especially with higher compression. Id take out .75 or 1 degree per # on the street as the additional timing isnt worth it at all.
if the car bogs in the top end w/ an uberdata basemap, dont be surprised. i was at a 1200 fuel value at 5k rpm and only 550 or 600 at 7k rpm. Car runs out of breath fast w/ a non-vtec.
sam
Old Sep 26, 2003 | 10:33 AM
  #290
Rakka's Avatar
Default Re: My new Uberdata setup! (94lsboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost &raquo;</TD></TR><TR><TD CLASS="quote">How does the boost control option work?? i dont mind losing a/c...just can you tell me how it actually works?? thanks!</TD></TR></TABLE>
it uses the a/c clutch line output to toggle a boost solenoid. GM boost solenoids are $17 from the dealer i think.
Old Sep 26, 2003 | 10:41 AM
  #291
c-way's Avatar
Default Re: Update on my Batronix programmer and some info (Overblown-Teg)
newbie question: correct me if I'm wrong, but do i have to take out the 29c256 chip to make changes to the ecu? if so how would i tune it at a dyno? or(240/NewInjectorSize*100)+5 is this all i need to run a happy boost life. tx!
Old Sep 26, 2003 | 11:23 AM
  #292
Default Re: Update on my Batronix programmer and some info (c-way)
ok guys I really am a moron.. I cant find the com port settings.. where do I go to change them? i tried plugging it in direct and I still get the sector 0 error
Old Sep 26, 2003 | 11:41 AM
  #293
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c-way &raquo;</TD></TR><TR><TD CLASS="quote">newbie question: correct me if I'm wrong, but do i have to take out the 29c256 chip to make changes to the ecu? if so how would i tune it at a dyno? or(240/NewInjectorSize*100)+5 is this all i need to run a happy boost life. tx!</TD></TR></TABLE>
bring your computer to tune on the dyno. and you do need to take the chip out
sam
Old Sep 26, 2003 | 12:51 PM
  #294
B94Cast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">ok guys I really am a moron.. I cant find the com port settings.. where do I go to change them? i tried plugging it in direct and I still get the sector 0 error
It is not through your serial (com) port, it is through your parallel port. To change the settings on this... depends on your computer. Most computers you need to reboot, hit the appropriate key to enter your bios, and find the port section. (you usually hit DEL, F2, or F8 depending on who made your PC to enter the BIOS or Setup).
Old Sep 26, 2003 | 02:01 PM
  #295
blundar's Avatar
I think this thread demonstrates that you truly have made Uberdata idiot proof Blake. Congratulations.
Old Sep 26, 2003 | 02:29 PM
  #296
Default Re: Update on my Batronix programmer and some info (B94Cast)
Ok I got to the setup and the settings for parrellel port. But mine are like this 378-37f, 778-77d, IRQ 7, dma 3
What should I set it to?
Old Sep 26, 2003 | 08:36 PM
  #297
B94Cast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">Ok I got to the setup and the settings for parrellel port. But mine are like this 378-37f, 778-77d, IRQ 7, dma 3
What should I set it to? </TD></TR></TABLE>
That would be your resource settings. You need to find the mode section, and change it from ECP/EPP to SPP or just ECP or EPP.
HTH!
Old Sep 26, 2003 | 08:59 PM
  #298
B94Cast's Avatar
Default slashDevslahNULL - ghetto hand wriiten website
http://www.b94cast.com/uberdata/
Here is slashDevslahNULL's ghetto hand wriiten website. I have removed the uberdata program files until he or I hears from Pueblo whether or not it is okay to post the program. Otherwise, enjoy!
Old Sep 26, 2003 | 10:13 PM
  #299
baphomet's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (B94Cast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B94Cast &raquo;</TD></TR><TR><TD CLASS="quote">http://www.b94cast.com/uberdata/
pueblo cares not, thanks for putting it up - sorry everyone about how crude it is, but the noobs have some helpful links in one place.
Old Sep 26, 2003 | 10:22 PM
  #300
rjardy's Avatar
Default Re: slashDevslahNULL - ghetto hand wriiten website (slashDEVslashNULL)
very cool, you put that together, tahnks
Rob
