newest uberdata released
Old Sep 22, 2003 | 10:12 PM
  #51
B94Cast's Avatar
Default Re: newest uberdata released (Rakka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rakka &raquo;</TD></TR><TR><TD CLASS="quote">...an eprom burner is cheaper than an afc, and much more accurate.</TD></TR></TABLE>
I ordered the software setup through drop shop 8 days ago... also ordered the batronix burner. Cant wait for both to show up!!!
Old Sep 22, 2003 | 10:15 PM
  #52
baphomet's Avatar
Default Re: newest uberdata released (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">add 58.3 to just the multiplication part, not where it says addition right under it right?
sorry for all the questions, andt thanks for not getting inpatient with me
Rob</TD></TR></TABLE>
yup
No prob, it must be the night air, brings out the best in me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">allso it wont let me add a decimal, so just 58% ?</TD></TR></TABLE>
you sure, I just did it - let me double check
edit: hmm, mine takes a decimal just fine.
Old Sep 22, 2003 | 10:19 PM
  #53
cornhusker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rakka &raquo;</TD></TR><TR><TD CLASS="quote">Cornhusker, also pull timing in the 4500 row.</TD></TR></TABLE>
so pueblo, add fuel and pull timing in the 3500, 4000, and 4500 rows and in the 25, 23, and 20 columns?
Old Sep 22, 2003 | 10:20 PM
  #54
rjardy's Avatar
Default Re: newest uberdata released (slashDEVslashNULL)
yeah i type in 58.3 and it puts583 in there..
Rob
Old Sep 22, 2003 | 10:21 PM
  #55
rjardy's Avatar
we are talking about the multiplication block under where it says "math" right?
Rob
edit: im retarded, you have to put it in the addition block
Old Sep 22, 2003 | 10:25 PM
  #56
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">we are talking about the multiplication block under where it says "math" right?
Rob
edit: im retarded, you have to put it in the addition block </TD></TR></TABLE>
umm, In the multipliction block, it takes my decimal value.
So what happens when you type '.'?
I am tempted to get a screen shot lol, but I am too tired. Not in the addition. If it doesn't work, dl another copy. It will not scale the same if you enter it in the addition box.
BTW, Im running it under wine, but I don't see how that would affect this situation.
edit: I just realized that some people might not know what wine is, lol I'm not drunk
It stands for Wine Is Not An Emulator or something I need to get some sleep. Its a windows emu. for linux
Let me know if it works, you have got me all anxious now lol.
Modified by slashDEVslashNULL at 11:36 PM 9/22/2003
Old Sep 22, 2003 | 10:36 PM
  #57
rjardy's Avatar
damn, it just wont take it, it acts like im not evan punching the key. It will however take it under addition, but not in the multiplication block. maybe I will DL another copy.
Rob
Old Sep 22, 2003 | 10:53 PM
  #58
nevin's Avatar
mine makes a error beep sound when i press "." in the multiplication block.
Old Sep 22, 2003 | 11:01 PM
  #59
baphomet's Avatar
Default Re: (nevin)
maybe I got the funny one or maybe it is wine. Pueblo?
edit: I'll go into winbloze tomarrow to confirm.
Old Sep 22, 2003 | 11:23 PM
  #60
Rakka's Avatar
Default Re: (slashDEVslashNULL)
The edit window is a # only field, windowz should block any non-numerical keystrokes, but I guess it doesnt in your version. The ecu's math isnt accurate for decimals (the fuel values get rounded when you save the bin). So theres no need for the multiplier to have decimals.
edit: I see you are running a windowx emulator, well you just found a bug! w00t
corn husker: pull timing and add fuel throughout all of the map ranges, and between 3500 and 4500 rpm ranges. If you dont, it will stop retarding and adding boost once u get above 0psi (which is pointless cuz u want it to continue to build boost!)
this is my 5 post limit for my trial user status, i wont be able to reply for awhile.
Old Sep 22, 2003 | 11:53 PM
  #61
Mr. Softee's Avatar
Default Re: (Rakka)
for larger map sensors divide 1.7bar/newmap sensor peak value (unit is bar) and then realize then multiply the actual amount of pressure by this value to get the fuel value column the ecu is pulling out of the ecu.
Old Sep 23, 2003 | 01:25 AM
  #62
rjardy's Avatar
Default Re: (94goldjungsr)
so will this le you run a 3 bar?
Rob
Old Sep 23, 2003 | 03:00 AM
  #63
racerboyb18c1's Avatar
Default Re: (rjardy)
so for all motor would this work
and if so how would i make a fuel map for above 9 grand?
Old Sep 23, 2003 | 04:25 AM
  #64
rjardy's Avatar
Default Re: (racerboyb18c1)
" Second, get your hardware supplies. You need one - 1/4 Watt 1.0k resistor, two
0.1uF Ceramic Disc capacitors, one 74HC373 IC, and a 28-pin 29c256 eprom.
I get my chippling supplies from radio shack and jdr.com. Radioshack wont have the eproms"
Is there a schematic or something that explains exactly where these things go? kinda lost here.
Rob
Old Sep 23, 2003 | 04:51 AM
  #65
civperc's Avatar
hmm, I'm getting pretty darn interested in this. Spending 1000 total in Hondata costs is kinda pricy for me, so this might be a better solution.
Old Sep 23, 2003 | 05:08 AM
  #66
coyote's Avatar
Default Re: (untensadude)
ya me too ! to bad it's for the OBD1 guys . maybe i will have to switch over hmmm why cant someone write one for Obd0 ....
Old Sep 23, 2003 | 05:16 AM
  #67
Crazy Cooter's Avatar
Default Re: (coyote)
I'm not familiar with OBD0, but isn't gettodyne exactly for that?
Old Sep 23, 2003 | 05:52 AM
  #68
COOKIEPUSS's Avatar
Default Re: (Crazy Cooter)
Thanks for all the usefull informations, and free downloads.
I'm curious, if you have an OBD2 car, can you switch it to OBD1 and tune it that way? I have an 00Si that will have 10psi of boost, and a P28 ECU, I could use that and start w/ a GSR base map?
Thanxs for all the help, and help to come. Great Work!!!! If I find this software usefull, I defiantly make a donation, hard work shouldn't go unnoticed!!!
Old Sep 23, 2003 | 06:26 AM
  #69
BuddyLee's Avatar
Default Re: (COOKIEPUSS)
i feel somewhat knowledgable on this program, ive been following it since it was realized, but i have one noob question....
will this work on an auto tranny??
Old Sep 23, 2003 | 07:26 AM
  #70
hoggy's Avatar
Default Re: (BuddyLee)
Is there anywhere to download more basemaps, I'm guess not?
Anybody have any basemaps they want to share?
Old Sep 23, 2003 | 07:51 AM
  #71
T-RO's Avatar
pgmfi.org has a section where you can download ROMS (maps)
Here is where I got my Stock ROMS from, they dont look right in Uberdata though. Any ideas?
http://www.pgmfi.org/phorum/do...m.zip
Modified by T-RO at 4:16 PM 9/23/2003
Modified by T-RO at 4:21 PM 9/23/2003
Modified by T-RO at 4:22 PM 9/23/2003
Old Sep 23, 2003 | 08:33 AM
  #72
cornhusker's Avatar
Default Re: (T-RO)
here is a tuned hondata map to look at (not sure about injectors though). but i think it would be a good place to start.
http://hondata.com/techpartthrottle.html
http://hondata.com/tunes/turbogsr.tun
Old Sep 23, 2003 | 08:58 AM
  #73
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">" Second, get your hardware supplies. You need one - 1/4 Watt 1.0k resistor, two
Try this
I might know of another, let me look......
Old Sep 23, 2003 | 09:01 AM
  #74
hoggy's Avatar
Default Re: (T-RO)
I don't know about everyone else....but I think this post rocks.
This has been the most informative, helpful, and money saving information I have read on the internet in month.
Thanks to all and keep the info coming. I'm sure there are others interested that need some help.
Old Sep 23, 2003 | 09:07 AM
  #75
ScottEK's Avatar
Default Re: (hoggy)
This is a great thread, I'm glad to see Uberdata back on HT. I had a couple questions after reading this thread.
Would you use the GSR rom for a B16 engine also?
Does the engine fire lean during the FTL since it utilizes fuel cut? Also is there hesitiation in other gears at your FTL RPM since it has additional fuel and retarded timing?
