newest uberdata released
Old Sep 25, 2003 | 12:27 PM
  #251
youngkow's Avatar
Default Re: (T4sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4sol &raquo;</TD></TR><TR><TD CLASS="quote">
Wow....4 days and almost 4000 views. Blake u should be proud! </TD></TR></TABLE>
Yeah, it's almost like a girl created this post.
Anyways, great post! I just got all my stuff so hopefully I'll burn my first chip tonigh.
Old Sep 25, 2003 | 12:33 PM
  #252
Mr. Softee's Avatar
Default Re: (youngkow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngkow &raquo;</TD></TR><TR><TD CLASS="quote">
Old Sep 25, 2003 | 01:32 PM
  #253
Rakka's Avatar
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">
You got something you want to tell us sam(antha)?
Old Sep 25, 2003 | 01:34 PM
  #254
Mr. Softee's Avatar
Default Re: (Rakka)
Old Sep 25, 2003 | 01:35 PM
  #255
youngkow's Avatar
Sorry, didn't mean it like that. What I meant was that when a girl posts something on h-t, the view count goes up like crazy.
Old Sep 25, 2003 | 01:48 PM
  #256
Mr. Softee's Avatar
i know
Old Sep 25, 2003 | 02:07 PM
  #257
raene's Avatar
OK I'm a little confused... I just bought solder wick, 2 capacitors, the resistor, a 74HC373 20-pin chip and a 20-pin I.C. socket. I still need a 28-pin ZIF and the Atmel chips, but what do I do with the 20 pin chip and socket? Does the chip have to be burned, or did I even need to buy the chip? The only thing we've talked about is the Atmel chips... dang I feel like a we-todd right now
Old Sep 25, 2003 | 02:13 PM
  #258
toxicshit's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">OK I'm a little confused... I just bought solder wick, 2 capacitors, the resistor, a 74HC373 20-pin chip and a 20-pin I.C. socket. I still need a 28-pin ZIF and the Atmel chips, but what do I do with the 20 pin chip and socket? Does the chip have to be burned, or did I even need to buy the chip? The only thing we've talked about is the Atmel chips... dang I feel like a we-todd right now </TD></TR></TABLE>
no the 74HC373 is a 8 bit tri-state Latch and you can solder it in with no kind of programming.
Old Sep 25, 2003 | 02:37 PM
  #259
raene's Avatar
Default Re: (toxicshit)
WTF did I buy then?
Chipped P28 ECU picture from PGMFI.org shows what I bought - looking at the 74HC373 part outlined in red. It looks like a big freakin' 20-pin socket to me! What I bought is identical to that 20-pin socket seen in the picture.
Old Sep 25, 2003 | 02:45 PM
  #260
Mr. Softee's Avatar
Default Re: (raene)
just solder the 20 pin socket in the 20 pin spot and put the 20 pin chip in there... then do the same in the 28 spot. the capacitors go above hte 20 pin. the resistor goes to the right of the 28. the j1 is below that. its cake.
Old Sep 25, 2003 | 02:55 PM
  #261
raene's Avatar
Okee doke, thanks
I haven't gotten the chip yet so that's probably why I'm so confused. No visuals!
And you guys think this thread has a lot of responses now... wait until I start asking tuning questions
Old Sep 25, 2003 | 06:27 PM
  #262
hulkhb's Avatar
Default Re: (raene)
AHHH SIITTT boys and girls i just got my done thanks to the help of T4sol. He did all the soldering. THANKS AGAIN MAN.
I took the car out for a spin and wow, feels totaly smooth transition is flawless.
I didn't want to push it too far being that i dont have a WB yet. But i took it to 3psi and had to pry my foot off the pedal, i wanted to take it to redline SO bad.
well all i have to say is thanks, this is an awesome product!!!
now if i can just figure out what all those numbers mean in the program i'll be alright
I need to save $ for a WB and dyno time.
My setup (for those who care)
00 B18C5 in a 98 EK HB
Tial WG 6.5psi spring
550cc's from RX-7
29X2.5X6.5 FMIC
2.25" IC piping
TurboXS type S bov
3" full DP and full exhaust by ME - PM me for quotes
OBD2-OBD1 conversion harness by Blown90Hatch
Uberdata
Old Sep 25, 2003 | 06:38 PM
  #263
rjardy's Avatar
Default Re: (hulkhb)
awesome
Rob
Old Sep 25, 2003 | 06:40 PM
  #264
Mr. Softee's Avatar
Default Re: (rjardy)
if you guys ever solder an ecu and it goes into limp mode (cel solid, 3k revlimt) add more solder to the connections. just a hint ive learned.
sam
Old Sep 25, 2003 | 07:39 PM
  #265
B94Cast's Avatar
Default Update on my Batronix programmer and some info
After reading many posts here about users getting the same errors I had with the 29c256 started to wonder about the shielding, noise, and the fact that the batronix does not have any memory to store any data on. So if it misses a bit or more of data, those chunks of data are gone. That, and perhaps the port was sending data the batronix did not like for some reason on those chips. So, I went into my BIOS, set my parallel port to SPP from ECP, undid the shroud on my batronix, and plugged it DIRECTLY into my parallel port. And Voila! Programmed perfectly time after time. No errors after many writes. Back to the cable - I can write a 27C256 fine, but the 28C256 started mis-matching data again.
So, happy with that, I went out into the garage with my newly written 28C256, and nada except CEL solid and running poorly... I did a bit of digging, and apparently the 28C256 is not a chip that the ECU likes.
So for all of the Batronix users out there: If you are having write mode issues, try plugging it in Directly to your parallel port, and put the port into SPP mode.
Everyone else: Dont get a 28C256 series chip!
Old Sep 25, 2003 | 07:58 PM
  #266
Mr. Softee's Avatar
Default Re: Update on my Batronix programmer and some info (B94Cast)
i enver had any problems writing to a 29c256. the only times i did i remade the file and it worked, or once i had to reboot becuase it wouldnt write to 0 sector or some **** and it worked
sam
Old Sep 25, 2003 | 08:23 PM
  #267
baphomet's Avatar
Default Re: Update on my Batronix programmer and some info (94goldjungsr)
I put together a ghetto hand wriiten website if anyone cares, and added a little html to the faq. I have no place to host it - not that it matters - since pgmfi will be the official place. Anyway, just sharing because I'm bored If anyone wants it or whatever I'll tar it for you.
edit: for those of you that can't untarI'll see if I can zip it or something (damn winbloze)
edit: Rakka, someone wants to host it - if you give the okay. BTW, check your email.
Modified by slashDEVslashNULL at 10:25 PM 9/25/2003
Old Sep 26, 2003 | 05:29 AM
  #268
94lsboost's Avatar
Default Re: uberdata (Poop111444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poop111444 &raquo;</TD></TR><TR><TD CLASS="quote">I will setup a webpage with assorted MAPS for different setups to get people started with their tuning.
Post up if your interested. I have some, and i'll like to build a site and let peeps download the maps.
Example: Turbo b16a2 8psi, 450cc injectors, T3/T4e
Sweet if you can do that.... Turbo b18b1 10psi max, dsm450's, garret tb0343
Old Sep 26, 2003 | 05:42 AM
  #269
int3gra's Avatar
Default Re: Update on my Batronix programmer and some info (slashDEVslashNULL)
send it over i'll put it up.
syndk8@rogers.com
Old Sep 26, 2003 | 05:47 AM
  #270
94lsboost's Avatar
Default Re: My new Uberdata setup! (Rakka)
How does the boost control option work?? i dont mind losing a/c...just can you tell me how it actually works?? thanks!
Old Sep 26, 2003 | 05:52 AM
  #271
Overblown-Teg's Avatar
I keep getting the sector 0 error.. You guys think it could be the cable? I will try pluging it in direct tonight and then changing the port setting. I'm getting pretty frustrated with this thing not working..
Old Sep 26, 2003 | 05:57 AM
  #272
toxicshit's Avatar
Default Re: My new Uberdata setup! (94lsboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsboost &raquo;</TD></TR><TR><TD CLASS="quote">How does the boost control option work?? i dont mind losing a/c...just can you tell me how it actually works?? thanks!</TD></TR></TABLE>
I want to know to PLEASE
Old Sep 26, 2003 | 06:04 AM
  #273
B94Cast's Avatar
Default Re: Update on my Batronix programmer and some info (Overblown-Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg &raquo;</TD></TR><TR><TD CLASS="quote">I keep getting the sector 0 error.. You guys think it could be the cable? I will try pluging it in direct tonight and then changing the port setting. I'm getting pretty frustrated with this thing not working.. </TD></TR></TABLE>
I was getting sector 0 error and sector 10 error. That fixed it for me!
Old Sep 26, 2003 | 06:05 AM
  #274
civperc's Avatar
which burner are you using? batronix?
Old Sep 26, 2003 | 06:15 AM
  #275
Default Re: Update on my Batronix programmer and some info (untensadude)
I'm using the batronix.. all my 27c chips are full so I can't try them.. I will try hooking it up direct tonight and see if that works for the 29c chips.. I really want to be able to tune.. I have had a base chip in for a while now and its pretty rich.. other than that it works good.
