Another GM 3 bar Map Sensor Install Question ! where the hell does it go.
Old Mar 25, 2002 | 03:02 PM
BLKCRX's Avatar
Default Another GM 3 bar Map Sensor Install Question ! where the hell does it go.
hey all i know a while back dustin had a pic of his 3bar GM map sensor plugged up on his car... god knows what the url was...iv seached his http://rely.net/~dustin/ site.
but im just wondering where the hell does a GM 3bar map sensor go, and which sensor does it replace.. iv looked on the hondata website that shows / talks about how to wire it up correctly... but i think the install notes forgets 1 think.. where the hell is the stock map sensor that the 3bar gm sensor replaces... iv searched my engine bay for a connector that looks like the GM connection with no luck..
also that little intake pipe on the GM 3bar Map sensor, im assuming thats where a vacuum line goes yeah ? but from where...b/w my car is a b16a2 crx (del sol) if that makes a difference.
Regards James
Old Mar 25, 2002 | 07:43 PM
VaporTrail's Avatar
New User
Default Re: Another GM 3 bar Map Sensor Install Question ! where the hell does it go. (BLKCRX)
um, the GM 3 bar map sensor replaces (drum roll please) the stock map sensor . It does not plug in or mount like the stocker. It needs to be run to a vaccum/boost source.
Old Mar 25, 2002 | 09:28 PM
93LSivic's Avatar
Here ya go mate....
http://hondata.com/3barinstall.html
Old Mar 25, 2002 | 11:13 PM
BLKCRX's Avatar
Default Re: Another GM 3 bar Map Sensor Install Question ! where the hell does it go. (93LSivic)
but WHERE is the stock sensor located.. (that info is not on the hondata site)
no drum roll needed !! eheh
i know what i need 2 do...to it once i located it..
Regards James
Old Mar 26, 2002 | 12:02 AM
VaporTrail's Avatar
New User
oh ****, that's easy.
On 91 and older motors/cars, it's located on the fire wall.
On 92+, it's located on top of the throttle body. Black sensor, three wire plug going on it.
Old Mar 26, 2002 | 12:03 AM
BLKCRX's Avatar
Default Re: Another GM 3 bar Map Sensor Install Question ! where the hell does it go. (VaporTrail)
YAY.. but hummm
the plug to the stock sensor is nuffing like the plug on the GM sensor.. i guess ill have to do something.. to make it fit..../ work...
Regards James
Old Mar 26, 2002 | 03:18 AM
Arturbo's Avatar
Better than steak
25 Year Member
Wire tie the sensor to the fire wall. Then have a vaccum line from the sensor to a port where the stock sensor used to be. Or just make a plate where the stock sensor used to be and t-off one of your lines on the manifold. Did that answer your question? Email me if it didnt...
art
Old Mar 26, 2002 | 09:58 AM
VaporTrail's Avatar
New User
YAY.. but hummm
Regards James
Are you sure you should be installing this? I've said it already, it does NOT plug in to the stock harness. You have to cut the stock plug off, and wire it into the pig tail harness that you need to purchase . I won't walk you through this any further, you need spoon feeding
Old Mar 26, 2002 | 12:59 PM
BLKCRX's Avatar
Default Re: Another GM 3 bar Map Sensor Install Question ! where the hell does it go. (94hondahybrid)
heheh thanks for ya help guys !! it cleaned up my mind.. in what has to be done .. to make it work !! no spoon feeding needed....
out here in aust.. turboing a honda is never hurd of.. gota make sure we do eveything 100% right..
Old Mar 26, 2002 | 01:06 PM
VaporTrail's Avatar
New User
ahhhhh, that explains it. Didn't realize you were out of this country. My apologies for being so arrogant.
Old Mar 26, 2002 | 01:10 PM
BLKCRX's Avatar
thats ok apologies accecpted... next time i have a problem ill PM you eeheh directly
jk
its hard being like one of the 1st b engine turbo honda's out here... esp doing it US style... but im loving all the experence.
Regards James...
Old Mar 26, 2002 | 01:13 PM
Pritos's Avatar
New User
You can find those pigtail connectors at any Pepboys or Kragen. There is always a section that includes gm connectors. Try next to the trailer-hitch and tail-light converters.
Old Mar 26, 2002 | 01:16 PM
Cramerox's Avatar
James hows your max rev kit going? im still waiting on mine..hopefully next week. are u boosting yet? what are u doing for fmu? hondata?
Old Mar 26, 2002 | 01:21 PM
abraunb16's Avatar
New User
Default Re: Another GM 3 bar Map Sensor Install Question ! where the hell does it go. (Pritos)
Actually the pigtail connector is no-longer stocked at Pep Boys in Arizona(don't know about other states). It's a special order item now that takes 7 days. Guess how I know this? I just called GM and gave them the part number for the 3 Bar, they gave me the part number for the pigtail and I ordered both. The part was a little more expensive, but I was able to buy it that day and not have to wait for Pep Boys. To bad I couldn't use it that day. Oh well, just thought I'd share!
Old Mar 26, 2002 | 01:41 PM
BLKCRX's Avatar
Default Re: Another GM 3 bar Map Sensor Install Question ! where the hell does it go. (abraunb16)
pigtail connector ... now im lost ehhehe ill just use the soldering iron.. and solder the wires directly i think....somehow ! ill figure it out when i do it.
As revmax kix.. im still not boosting yet..
ben from inport parts is about to send the 2nd half of my turbo kit.. also
the wastegate came with a .65bar spring. and now i also have to get a smaller spring bc ill boost with stock internals 1st.. before i build my engine and then i hope boost to 18psi ! with my sleeved block / pistons / rods
Regards James
and yeah im using hondata with 550cc injectors and a new fuelpump intake and aem Fuelpump regulator.
ill update ya guys sooon on how the maxrev kit goes....
Regards James
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
EJ8 GSR-T
Mar 29, 2007 06:48 PM
JMinSi2000
Jul 29, 2004 08:47 AM
1.8T_EG
May 12, 2003 09:58 PM
austrian type-R
Sep 1, 2001 05:16 PM
