Installing GM 3 bar map sensor
Old Jun 27, 2003 | 01:31 PM
CiViC SiR's Avatar
Default Installing GM 3 bar map sensor
how can i install the GM 3 bar map sensor?
Old Jun 27, 2003 | 01:57 PM
PWRVTEC's Avatar
Default Re: Installing GM 3 bar map sensor (CiViC SiR)
Here you go http://www.hondata.com/3barinstall.html
Old Jun 27, 2003 | 02:27 PM
TurboCX's Avatar
http://forum.aempower.com/bbs/viewtopic.php?t=260
This will show you as well. Good luck!
Old Sep 14, 2003 | 09:16 AM
allmotor.net's Avatar
Default Re: Installing GM 3 bar map sensor (TurboCX)
did he really mean aem map sensor on that pic or did he mean OEM map sensor?
Old Sep 14, 2003 | 09:22 AM
MayhemSi's Avatar
I think he's looking for the same thing I am, the pigtail... GM wants almost 30 dollars for it!
Old Sep 15, 2003 | 10:28 AM
EG6owner-T's Avatar
Default Re: Installing GM 3 bar map sensor (MayhemSi)
can you install it using a different vaccum port?
like hook the source to a vaccum manifold?
Old Sep 15, 2003 | 10:51 AM
95c1v1cs1's Avatar
Default Re: Installing GM 3 bar map sensor (EG6owner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6owner &raquo;</TD></TR><TR><TD CLASS="quote">can you install it using a different vaccum port?
like hook the source to a vaccum manifold?</TD></TR></TABLE>
Yes, you can hook it up to some other source of Vaccum.. I left the stock map sensor in place so that it won't leak and tee'd off a vaccum source from the manifold.
Go to the Junkyard for a Pigtail... They are all over the place and you only have to pay like 5 bucks for them.
P.S. Try Searching if you completely understand the install, There is Lots of info on the 3bar map sensor including install info.
Corey
Old Sep 15, 2003 | 01:22 PM
the-anti-crack's Avatar
Default Re: Installing GM 3 bar map sensor (95c1v1cs1)
go to the junk yard for the pigtail......i got mine for a dollar
Old Sep 15, 2003 | 01:41 PM
. o 69 o .'s Avatar
Default Re: Installing GM 3 bar map sensor (the-anti-crack)
what cars do they come on? or do they come on all gm's?
Old Sep 15, 2003 | 06:51 PM
95c1v1cs1's Avatar
Default Re: Installing GM 3 bar map sensor (B16B)
I got mine from a Cadi...
Old Sep 15, 2003 | 06:58 PM
got mine off a cavaleer....
Old Sep 15, 2003 | 07:02 PM
SiRkid's Avatar
i found mine at a muffler shop
havent installed the 3bar though.
Old Sep 15, 2003 | 07:34 PM
. o 69 o .'s Avatar
is it screwed onto the throttle body, or is it attached to teh firewall like honda did on some models
Old Sep 15, 2003 | 07:43 PM
you pretty much have to put it on the firewall.....it is totally diferent desigin from stock. look at the picture above and you will see.
Old Sep 15, 2003 | 10:32 PM
accordfreak's Avatar
here's mine... dunno if you're looking for that..
Old Oct 19, 2003 | 08:42 AM
integra-modder's Avatar
Anyone know if it is ok to T off of the map sensor line for a boost guage if they are right next to each other, minimal hose lengths?
Old Oct 19, 2003 | 11:28 AM
see2k's Avatar
Default Re: Installing GM 3 bar map sensor (integra-modder)
i made sure that the map sensor was on its own connection, no tee no nothing.
you don't want the map sensor to mis read any of the info...
Old Oct 19, 2003 | 07:52 PM
Default Re: Installing GM 3 bar map sensor (see2k)
what did you get a boost reading off of?
Old Oct 20, 2003 | 09:08 AM
BuiltB18C1
Guest
Posts: n/a
bump.
Old Oct 20, 2003 | 11:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">what did you get a boost reading off of?</TD></TR></TABLE>
Astig
Mar 27, 2007 06:55 PM
siblues
Jan 24, 2005 02:02 PM
1.8T_EG
May 12, 2003 09:58 PM
BLKCRX
Mar 26, 2002 01:41 PM
austrian type-R
Sep 1, 2001 05:16 PM
