... 3-bar map sensor install
Old May 12, 2003 | 09:53 PM
1.8T_EG's Avatar
Default ... 3-bar map sensor install
... just wanna confirm info found from searching... see below...
- order gm 3-bar map sensor and pigtail
- plug stock map sensor location
--- either with stock map sensor or block-off plate
--- mount gm map sensor as close as possible
- tap intake manifold for new vacuum source
- use pigtail for wiring
... did i get everything, or am i missing something?... lemme know... thanks in advance...
Old May 12, 2003 | 09:58 PM
Flamenco-T's Avatar
Default Re: ... 3-bar map sensor install (1.8T_EG)
you're correct..
stan
methos713
Jun 11, 2007 12:43 PM
MilanoFury
Oct 22, 2004 11:15 AM
ketchup_gsr
Sep 8, 2004 08:50 PM
ketchup_gsr
Nov 9, 2002 01:02 PM
