Lsv turbo setup
yo just wanted to give a run down of my setup and what my power goals are. Any suggestions would be great. Thanks
Setup:
STOCK b18a1 block w/new rings, bearings, fresh hone.
B16 head with mild PNP using arp headstuds
GSR cams
b16 intake manifold with hondata gasket stock TB
680cc injectors with resistor box
SPfab log style turbo manifold
Masterpower 57 trim turbo
going to be tuned on crome pro at 12psi using a P28 ecu on 93 pump gas i was hoping to see 350whp at 12psi. Any suggestions or comments are welcome.
Setup:
GSR cams
I think you would be over 300whp at 12psi on that, but I don't think it's going to be 350whp. Very good setup though. I just did an LS/Vtec build too with stock bottom end, just rebuilt it with new rings and such. Got it going to drive yesterday. Goodluck on your build
ok, I was looking at some for my bigger build i'm going to do from BWR, but they are on ebay so it's not actually coming from the BWR company, it's from a company that already has them.. that's where I bought my LS/Vtec conversion kit from. Anyways, they have them for $95 and they mount just like a normal map sensor would, I mean they are cheaper than the other brands and everything. That's what i'm buying when I get to upgrade, but right now i'm only going to run 10psi on mine.
