LS/VTEC Turbo?good?bad?
Old 07-21-2002, 07:41 PM
xTeg's Avatar
Default LS/VTEC Turbo?good?bad?
is this a good idea? it is an LS bottom end with a 99b16a head. i plan on building the motor up eventually but figured i can run about 10-12psi on this car as is. is it a smart idea to go turbo on this setup?
Old 07-21-2002, 07:42 PM
bretx0r's Avatar
Default Re: LS/VTEC Turbo?good?bad? (xTeg)
horrible, it will be slower than a VX motor for sure
Old 07-21-2002, 07:47 PM
xTeg's Avatar
Default Re: LS/VTEC Turbo?good?bad? (bretx0r)
it would be much more helpful if i could get a straight answer. i know i will be pushing plenty of hp i just want to know about reliability.
Old 07-21-2002, 07:55 PM
highmilehatch's Avatar
What will you be using for fuel and ignition?
Old 07-21-2002, 08:01 PM
New User
Pinhead's Avatar
Default Re: LS/VTEC Turbo?good?bad? (turboeg)
I'm sure if you built it right, ls/vtec will be a killer setup man. I am working on one myself should be done in a few months
Old 07-21-2002, 08:02 PM
xTeg's Avatar
rc injectors(size undetermined)
aeromotive fuel pump
fpr
hondata 2b
and if you have some suggestions my ears are open.
ignition is fully undecided, would like some help on a good ignition setup though
Old 07-21-2002, 08:03 PM
xTeg's Avatar
Default Re: LS/VTEC Turbo?good?bad? (Pinhead)
pinhead
may i ask what your setup is going to be?
Old 07-21-2002, 08:06 PM
New User
Pinhead's Avatar
it's a pretty basic turbo setup
B18B block with golden eagle sleeves
84.5mm Endyn pistons
Endyn/Eagle rods
Endyn oil pump
Moroso oil pan
Z10 girdle kit
B16 head ported by portflow
full ferrera valvetrain and valves
skunk2 intake manifold w/ported b16 throttle body
undecided tranny and turbo so far
Old 07-21-2002, 09:26 PM
Full-Race Geoff's Avatar
... dont do the girdle. Search.
i know many very very fast cars b20/LS motored that run no girdle. I also know ppl with girdles who had the girdle shift and lose a crank.
Old 07-22-2002, 03:40 AM
tegman2's Avatar
Default Re: LS/VTEC Turbo?good?bad? (FFgeoff)
Hey Geoff,
Did the people you know who had the girdle shift have the mains doweled and all that you said that would need to be done to the Z-10 to make it function properly? Or did they just put the girdle on?
Thanks,
Aron
Old 07-22-2002, 03:41 AM
New User
SIK IN DA HED's Avatar
Default Re: LS/VTEC Turbo?good?bad? (tegman2)
good when properly built.. bad if not done right.
Old 07-22-2002, 04:43 AM
BROOD's Avatar
Doweling it is the correct way to install the girdle (may it be Z10 or oem Honda). People having problems with the girdle shifting A. don't realize it yet, B. did not take the important steps to dowel the girdle to the caps, C. did not check the crankshaft bore alignment and align hone if nessesary.
[Modified by SLPR, 5:43 AM 7/22/2002]
Old 07-22-2002, 05:13 AM
boomslang's Avatar
How much hp were the ones with no girdle putting out?
Old 07-22-2002, 05:34 AM
Boost2NA's Avatar
Im building a LS-Vtec turbo motor myself. Im going to pick it up the first of ausust from Damon with Polk Performance. My set up consists of:
B18A Block with Golden Eagle Sleeves
9:1 Arias pistons (83mm)
Eagle Rods
Blueprinted GSR Oil pump
JG Proseries Head
JG Victor X manifold
AEM EMS
Hoping for 11s
Old 07-22-2002, 08:07 AM
BoOsTeD_eK's Avatar
Default Re: LS/VTEC Turbo?good?bad? (Boosted99Si)
I dont know how people could possibly build bad ls/vtec...it has less then 10 steps to do it. I have built for in my life...and not one of them has gone bad..for over a year and a hlaf on the youngest one. Its a killer motor...and mostly people who got raped buying gsr setups are usually the bitter ones HATING on the ls/vtec.
Old 07-22-2002, 09:45 AM
boomslang's Avatar
Default Re: LS/VTEC Turbo?good?bad? (BoOsTeD_eK)
up
Old 07-22-2002, 09:55 AM
CheezeFrog's Avatar
Default Re: LS/VTEC Turbo?good?bad? (Inlinefour)
Just out of curiosity how many Hondas are in the 8's or 9's on non-VTEC blocks?
Edit: What's the advantage of going with a non-VTEC block when it's a lot cheaper (50% almost) to just get your B18C1 block sleeved at Golden Eagle with 84mm bores?
[Modified by CheezeFrog, 10:57 AM 7/22/2002]
Old 07-22-2002, 09:58 AM
CheezeFrog's Avatar
mikeycivic
02-28-2008 05:22 AM
MxJones92
01-30-2006 10:52 AM
imonkie
10-02-2002 11:13 PM
boosted2seater
09-26-2002 06:10 PM
introspeed2
07-15-2002 08:46 PM
Quick Reply: LS/VTEC Turbo?good?bad?
