LS/Vtec ---------> reliable?
Old Oct 1, 2002 | 08:18 PM
imonkie's Avatar
Default LS/Vtec ---------> reliable?
i've been reading about LS/Vtec lately and was trying to decide if i wanted to slap a vtec head on my b18 block. I just wanted to learn more about the swap. My main question is reliability and what to do to build it right. thanks.
Old Oct 1, 2002 | 08:25 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: LS/Vtec ---------> reliable? (imonkie)
no
Old Oct 1, 2002 | 08:41 PM
TimoneX's Avatar
New User
Default Re: LS/Vtec ---------> reliable? (Jsracingintegra)
I personally think you'd be further ahead looking at a turbo setup, but LS/Vtec can be reliable if done right.
Old Oct 1, 2002 | 10:00 PM
PureTeg420's Avatar
pistons rods crank girdle, and upgrade your valvetrain. then you will have an ls/vtec which is reliable, and can rev to 8500rpms.
Old Oct 1, 2002 | 10:33 PM
nickb20vtec's Avatar
very reliable, if done right!
Old Oct 2, 2002 | 12:24 AM
randyman's Avatar
New User
Default Re: LS/Vtec ---------> reliable? (nickb20vtec)
i had a "stock" gsr head slapped on my "stock" b18b block with 130,000 miles. had that setup for 3 years. no problems. even squeezed on it too (55 shot). revved it to 8000 once in a while too.
opted for an all motor setup. so now i have a b20/vtec with all the goodies. i currently have that setup for a year now with no problems also. daily driven.
Old Oct 2, 2002 | 12:43 AM
S13 slide's Avatar
Default Re: LS/Vtec ---------> reliable? (randyman)
reliable as the builder imo
Old Oct 2, 2002 | 04:44 AM
2lowintegra's Avatar
Default Re: LS/Vtec ---------> reliable? (S13 slide)
word!!
Old Oct 2, 2002 | 05:11 AM
vtec69's Avatar
if it built right it can be very reliable
by building right i mean
change all crank bearing, new thrust washers, all new gaskets, stornger rods, vtec oil pump, vtec water pump, all new o rings, and pretty much dont rev past 8300 and you should never have a problem
Old Oct 2, 2002 | 07:58 AM
S13 slide's Avatar
Default Re: LS/Vtec ---------> reliable? (vtec69)
use arp rod bolts and a crank girdle if you plan on reving it, and have everything balanced.
Old Oct 2, 2002 | 08:43 AM
gsrvx's Avatar
New User
as everyone else said...if built right, will be reliable.
-Rod
Old Oct 2, 2002 | 09:27 AM
Boost2NA's Avatar
Default Re: LS/Vtec ---------> reliable? (RK)
1100 miles and still going. No problems yet.
Old Oct 2, 2002 | 10:26 AM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: LS/Vtec ---------> reliable? (Boosted99Si)
Build it right and find a good person to build it. It will be cheaper to do it, and do it right once, than to blow up your motor and have to do it twice....plus if done right, it will be much more beneficial.
Old Oct 2, 2002 | 11:20 AM
piatl7il77's Avatar
Default Re: LS/Vtec ---------> reliable? (integra707)
what he said
Old Oct 2, 2002 | 07:40 PM
imonkie's Avatar
thanks for all the info guys. This helps a lot. i wanted to find out more from the people who've had LS/vtec for awhile tho. I was also wondering what kinda head you used and what would be the best in your opinion. I was thinking GSR.
Oh yea...you know what to get heads that are good quality and for a good price?
[Modified by imonkie, 4:41 AM 10/3/2002]
Old Oct 2, 2002 | 08:26 PM
sic2kSi's Avatar
I'd say B16 head because there pretty aboundant, you know, should anything go wrong.
Old Oct 2, 2002 | 09:44 PM
giooooo's Avatar
yeah tru you know what sucks haveing a crx and second gen integra and stuck with and LS trans.. anyone here run an ls vtec with an ls trans or vtec motor with ls trans by anychance? if so how did it run with vtec crossover
Old Oct 2, 2002 | 10:42 PM
SMZ GSR's Avatar
Default Re: LS/Vtec ---------> reliable? (Giovannie)
Talk to DRFlickner on this board, he's had his ls/vtec for a while. He also ran it with his LS tranny for a while then got JDM SIR w/ LSD. car was quick still with the LS tranny but after he got the other one it was like night and day!
Old Oct 2, 2002 | 11:05 PM
giooooo's Avatar
Default Re: LS/Vtec ---------> reliable? (SMZ812)
in what car you know his setup?
Old Oct 2, 2002 | 11:07 PM
giooooo's Avatar
what did your ls vtec run? and waht tranny?
Old Oct 2, 2002 | 11:13 PM
SMZ GSR's Avatar
It is in his 99 LS coupe. i don't know everything he had thats why i recommend talking to him. i do know that it was a b16 head.
95_red_dc
May 30, 2006 07:53 PM
95_red_dc
May 24, 2006 01:02 PM
92integraVTECgsr
Nov 15, 2005 06:11 PM
lonslw
May 6, 2004 08:34 PM
juicedricer
Feb 15, 2003 08:03 AM
