LS/VTEC built bottom end on a t3/t04e turbo setup?
Im considering doing the ls vtec bottom end with turbo pistons, forged rods, and iron sleeves, and head studs. Will i be safe running this setup and will the power production be a good amount?? thanks for any info
Re: LS/VTEC built bottom end on a t3/t04e turbo setup? (boosted2seater)
Very good setup! Will be very safe with a good engine management system (ems or hondata)!
like tony said its great setup.. i have to agree hondata lsvtec 17 pounds you be making around 400hp just like jeff at importbuilders if dont right.
You might have already heard this, but research, research, research. Honda-Tech is full of info from reading compression maps to proper fuel management. search is you friend!!!
