just turbo b16
Old 01-15-2006, 07:13 AM
hoskos's Avatar
Default just turbo b16
i just bolted on my turbo on my stock b16.
how much psi will i be able to be on the safe side?
my water temp tends to overheat big time.
Could it be due to my intercooler blocking the radiator?
Old 01-16-2006, 12:18 AM
hoskos's Avatar
Default Re: just turbo b16 (hoskos)
nobbody??
Old 01-16-2006, 09:15 AM
dnbruut's Avatar
i can tell you to search....
what kind of management?
what kind of turbo?
you can blow up your engine with 2 psi and you can run 10+psi safe depending on setup/tune
Old 01-16-2006, 09:17 AM
dnbruut's Avatar
Default Re: just turbo b16 (dnbruut)
maybe you already blew your headgasket
Old 01-16-2006, 10:47 AM
y8-turbo's Avatar
i have seen 20+ psi on a stock b16, so if your overheating, yes check your head gasket, cus at this point tunning owned you, or your engine... good luck
Old 01-16-2006, 12:51 PM
T3T495GSR's Avatar
Default Re: (y8-turbo)
did you put coolant back in the radiator?
Old 01-16-2006, 02:07 PM
boosted-EG6's Avatar
i run 9 pounds on mine with type-r cams and it runs good
Old 01-16-2006, 02:35 PM
beerbongskickass's Avatar
Default Re: just turbo b16 (boosted-EG6)
PSI means nothing. General rule of thumb is around 300whp give or take depending on tuning for most b-series motors. I'd run 300whp daily on a stock B16 without worrying. The over heating is a problem though, so you should check that out and no it's not from the intercooler blocking the radiator.
Old 01-16-2006, 03:35 PM
Very Emergency!!
emotionisdead's Avatar
i have a boosted b16 in my ek. i run ten pounds tuned with chrome, a vafc, and a plx m300 wideband. i am using a single core half size radiator with a big pusher fan on the front side. no overheating here.
Old 01-16-2006, 05:10 PM
Naterror's Avatar
Start here next time before making a post like this:
https://honda-tech.com/zerothread?id=1024174
Old 01-16-2006, 05:25 PM
platinum00's Avatar
your not overheating because your intercooler is blocking the radiator. you have other problems.
what engine management are you using.
platinum.
Old 01-18-2006, 05:58 AM
hoskos's Avatar
Default Re: just turbo b16 (platinum00)
i'm running on my stock ecu, i've oredered my hondata, but it is taking years to come in
Old 01-18-2006, 07:46 AM
Brain3208's Avatar
Headgasket.....
if you fill the radiator up and drive the car around without boost(like anyone can actually do that anymore) does it take much longer for the car to overheat?
Brain
b16ajdmrex
05-23-2009 09:20 AM
lukerc45
11-23-2007 09:45 PM
alex288
04-28-2006 12:50 PM
Equilibrium
07-01-2005 09:13 PM
hoggy
03-13-2004 06:25 AM
Quick Reply: just turbo b16
