First time turbo'ing my B16
ok so all ive done in the past is NA on my B16 and B18C5 i have had. (blew the C5 thats why i have b16 . ok so im just looking for a setup that i can do on my B16 so that i can have it a DD but have the big HP so that when time comes i can stomp on the normal camaros and some of the BMW's. so what will be the best setup i can get. id rather peice together a turbo kit cause i already have piping and intercooler but i already took out my A/C and power steering(real men dont need it) thanks lucas
Re: First time turbo'ing my B16 (lukerc45)
what are you asking for? built motor specs soup to nuts and turbo setup? you going to stick with a stock motor? question for spanking camaro's is wayyy too vague.
Re: First time turbo'ing my B16 (m R g S r)
um its just stock motor know cause i want to go turbo and i cant run my 11:3:1 compression with a turbo setup i was told. i just want to have around 250WHP out of the stock B16 and have a good DD.
keep it the way it is a.d boost it you should make 250whp easy on pretty low boost.....the higher the compression the better the tune needs to be....
