oil return?
Old Feb 26, 2009 | 07:06 PM
turbo-crx's Avatar
Default oil return?
well im putting my 42r on finally and the room is very tight in the crx. The return flange is kinda horizontal, it does go down in a downward into the pan though. will i have any drain issues with it being horizontal?
Old Feb 27, 2009 | 12:11 AM
2004es2's Avatar
Default Re: oil return?
It should be as vertical as possible because the return is gravity fed. I wouldn't go furtther than a 45* angle for the eturn, but thats just me.
Old Feb 27, 2009 | 02:54 AM
turbo-crx's Avatar
i thought i seen a few cars with the line completely horizontal directly into the pan. it still goes straight down into the pan. it just comes out horizontally.
Old Feb 27, 2009 | 05:40 AM
dpetro1's Avatar
post a pic. are you saying the return port on the turbo is horizontal? if so that is not going to work. if you are saying the line makes an "L" shape then i think that would be fine
Old Feb 27, 2009 | 07:01 AM
turbo-crx's Avatar
yea the port is horizontal
Old Feb 27, 2009 | 09:30 AM
dpetro1's Avatar
then no that is not ok.
http://www.turbobygarrett.com/turbob...ly%20&%20Drain
see the section labeled oil drain, +/- 35* is the max variation. you are essentially at 90*, you will need to clock the turbo
MalcolmV8
Dec 5, 2011 05:29 PM
toolowsol
Feb 9, 2006 01:52 PM
torr
Apr 14, 2004 07:48 AM
reignofchaos
Jul 31, 2003 07:48 PM
b00stedsi
Jul 28, 2002 04:17 PM
