How to install 3 bar map sensor?
Old Jul 4, 2003 | 12:48 PM
CiViC SiR's Avatar
Default How to install 3 bar map sensor?
How to install 3 bar map sensor, i know the wiring i want to know how should connect it to throttle body?
Old Jul 4, 2003 | 12:49 PM
b18bturbo's Avatar
Default Re: How to install 3 bar map sensor? (CiViC SiR)
all you do is run vaccum line from the intake mani to the Map sensor. then you wire it to your standalone
Old Jul 4, 2003 | 12:51 PM
CiViC SiR's Avatar
Default Re: How to install 3 bar map sensor? (b18bturbo)
any vaccum line in intake mani?
Old Jul 4, 2003 | 02:51 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC SiR &raquo;</TD></TR><TR><TD CLASS="quote">any vaccum line in intake mani?</TD></TR></TABLE>
you want to have a dedicated line for a map..i.e. no t's or anything into it...and also make it as short as possible. i wouldnt go any longer then 8"
Old Jul 4, 2003 | 06:05 PM
shermanyang's Avatar
how are you running 18 psi without a 3 bar map sensor in the first place?? don't tell me you're running check lines!!??
Old Jul 5, 2003 | 01:07 PM
CiViC SiR's Avatar
Default Re: How to install 3 bar map sensor? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">how are you running 18 psi without a 3 bar map sensor in the first place?? don't tell me you're running check lines!!?? </TD></TR></TABLE>
missing link
Old Jul 16, 2003 | 10:50 PM
sneakypete's Avatar
With the missing link you can run more than 11 psi (stock map sensor)? How do you wire it up using a hondata s100 w/boost?
jlfrnce
Jan 28, 2008 02:03 PM
SpoolnByYou
Dec 29, 2005 10:00 AM
jeffchaisi
Mar 27, 2005 10:39 PM
integramic
Sep 7, 2004 01:44 PM
CiViC SiR
Oct 20, 2003 11:00 AM
