mounting ideas for the 3 bar map sensor
Old Sep 7, 2004 | 08:14 AM
integramic's Avatar
Default mounting ideas for the 3 bar map sensor
Would like some pictures or ways of mounting gm 3 bar map sensor. Does the map sensor have to be right on the thottle body?
Old Sep 7, 2004 | 08:21 AM
underpressure02's Avatar
Default Re: mounting ideas for the 3 bar map sensor (integramic)
No you run a vacuum line to it. I mounted mine on the firewall with two screws one on each side. I don't have pics of it but kind of self explanatory.
Old Sep 7, 2004 | 10:51 AM
Muckman's Avatar
Moderator in Chief
I think there is a small backet coming off the gm sensors with a hole in it. You can sandwiche that under something else like the throttle cable bracket on the firewall.
Old Sep 7, 2004 | 10:52 AM
BROOD's Avatar
Zip tie the MAP body to the brake lines on the fire wall. Then run your vacuum/boost line to it.
Old Sep 7, 2004 | 11:14 AM
RyanEJ8's Avatar
Default Re: mounting ideas for the 3 bar map sensor (BROOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROOD &raquo;</TD></TR><TR><TD CLASS="quote">Zip tie the MAP body to the brake lines on the fire wall. Then run your vacuum/boost line to it.</TD></TR></TABLE>
I was going to do this if I can't find anywhere to mount mine on the firewall.
Old Sep 7, 2004 | 11:20 AM
m3bluegsr's Avatar
Here's a pic of mine. You can see the three bar mounted in the back on the firewall. (has a green Plug with the vacume line to it.) also you can see the plate i made out of carbon fiber to cover the old Holes on the throttle body. Here ya go.
Old Sep 7, 2004 | 12:48 PM
RyanEJ8's Avatar
Default Re: mounting ideas for the 3 bar map sensor (m3bluegsr)
Do you have a better pic of the plate you made on the throttle body? I can't see it very well in that pic.
Old Sep 7, 2004 | 12:55 PM
ladysman's Avatar
Default Re: mounting ideas for the 3 bar map sensor (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a better pic of the plate you made on the throttle body? I can't see it very well in that pic.</TD></TR></TABLE>
Ha-Ha, this is a pic I took for you.
Old Sep 7, 2004 | 01:44 PM
m3bluegsr's Avatar
Default Re: mounting ideas for the 3 bar map sensor (ladysman)
Naw thats the best i can find. I just followed the outline of the sensor and Cut it out of carbon fiber. Then i screwed it in with the map sensor screws and sealed it with Ultra black rtv
Topdawgg
Jun 25, 2007 10:02 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
SpoolnByYou
Dec 29, 2005 10:00 AM
victoriasamantha
Aug 21, 2005 03:03 PM
CiViC SiR
Jul 16, 2003 10:50 PM
