whats the little thing on the 3 bar map sensor for? pic here
i notice the little tube on the 3 bar map sensor what is it for do i have to connect it to a vacum source?
Re: (jeffchaisi)
hook it up to your fuel line, most definately...
J/K , it gets routed to your Inake manifold so it can read the air pressure in the IM..
Re: (unsungsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungsohc »</TD></TR><TR><TD CLASS="quote">is it okay to run your map sensor off of a vacuum box?</TD></TR></TABLE>you mean the vacuum manifold? yes.
Re: (95gsrturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrturbo »</TD></TR><TR><TD CLASS="quote">should you be using a 3bar if you dont know???????????
maybe you should start smaller...</TD></TR></TABLE>
Agreed, unless someone else is tuning your car.
but its cool, atleast now you know that a MAP sensor actually needs a pressure source for it to work...
hatchinprogress
11-23-2004 08:21 PM
