map sensor wiring
Old Oct 15, 2007 | 06:31 PM
jlfrnce's Avatar
Default map sensor istallation
ok yes i have been searching, and cant seem to find out were all the vaccuum lines go to install this on an integra gsr, i found the wirind the the original but can seem to fig out the rest, so please help me out on this!
Modified by jlfrnce at 8:13 PM 10/15/2007
Old Oct 15, 2007 | 07:40 PM
mtber's Avatar
Default Re: map sensor istallation (jlfrnce)
What kind of map sensor are you trying to install ?
Old Oct 15, 2007 | 08:05 PM
jlfrnce's Avatar
Default Re: map sensor istallation (mtber)
gm 3 bar
Old Oct 15, 2007 | 08:13 PM
mtber's Avatar
Old Oct 15, 2007 | 08:19 PM
jlfrnce's Avatar
ok i have seen already and hav it saved, but my question is about the hose, where is best to run it to?
Old Oct 15, 2007 | 10:36 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlfrnce &raquo;</TD></TR><TR><TD CLASS="quote">ok i have seen already and hav it saved, but my question is about the hose, where is best to run it to?</TD></TR></TABLE>
A clean manifold pressure source.
You can T into a source on your intake manifold.
Old Oct 16, 2007 | 04:35 AM
MeanGreenMachine's Avatar
does this information posted above also apply to installing a motec 3 bar map sensor?
Old Oct 16, 2007 | 09:09 AM
mtber's Avatar
Default Re: map sensor istallation (MeanGreenMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">does this information posted above also apply to installing a motec 3 bar map sensor?</TD></TR></TABLE>
Yes, it should be the same
Old Oct 17, 2007 | 11:30 PM
gsrt's Avatar
how about motec 5 bar map? is it same?
Old Oct 18, 2007 | 12:36 AM
black_ek's Avatar
kool
Old Dec 9, 2007 | 11:07 PM
mike_paz17's Avatar
Thanks i need this to connect my gm 3 bar....
Old Dec 18, 2007 | 05:59 PM
Y2KCivicSiR's Avatar
BUMP I Needed this too
Old Dec 19, 2007 | 12:02 PM
ctr83's Avatar
the gm map sensor what gm cars did they come on??
Old Dec 19, 2007 | 12:29 PM
DA_HONDA_BOY's Avatar
Default Re: map sensor istallation (ctr83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr83 &raquo;</TD></TR><TR><TD CLASS="quote">the gm map sensor what gm cars did they come on??</TD></TR></TABLE>
v6 and v8 chavys and cattys 88-on up
Old Dec 19, 2007 | 02:02 PM
Mr.Blondie's Avatar
wat about 4 bar Motorla?
Old Dec 19, 2007 | 02:51 PM
nfn15037's Avatar
Default Re: (Mr.Blondie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Blondie &raquo;</TD></TR><TR><TD CLASS="quote">wat about 4 bar Motorla?</TD></TR></TABLE>
What about it? All automotive MAP sensors that we are dealing with in the context of a Honda have 3 wires. +5V, GND, and signal. Your sensor should come with some sort of documentation and figuring out the wiring on the car is easy or just use the wire colors in your service manual or the ones shown above in this thread.
Old Dec 19, 2007 | 02:54 PM
have no eye deer LOL
Old Dec 19, 2007 | 06:46 PM
mtber's Avatar
Default Re: (DA_HONDA_BOY)
http://img92.imageshack.us/my....2.jpg
Old Dec 20, 2007 | 02:12 AM
Marlon88's Avatar
I had put a T fitting to the pipe that goes to the fuel press regolator.
Old Dec 21, 2007 | 11:57 AM
Mr.Blondie's Avatar
the motorla 4 bar is a damn small sensor smaller then a penny. sry for the confusion but I just wanted to kno how to hook it up
Old Dec 21, 2007 | 12:08 PM
nowtype's Avatar
http://www.xenocron.com/catalo....html
Old Dec 23, 2007 | 09:51 AM
Mr.Blondie's Avatar
do I have to buy a circuit board? for the motorola 4 bar?
Old Dec 23, 2007 | 11:20 AM
nowtype's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Blondie &raquo;</TD></TR><TR><TD CLASS="quote">do I have to buy a circuit board? for the motorola 4 bar?</TD></TR></TABLE>
No, but based on the fact you've asked this question twice, I'd suggest it strongly. If you ask the question again, I'm going to break out the profanities and point out the fact you are another idiot French Canadian. Figure it out or buy the board. It's a map sensor. It calls for 3 wires. If you can't figure it out, then you are dumb.
Old Dec 23, 2007 | 12:34 PM
nfn15037's Avatar
Default Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">
No, but based on the fact you've asked this question twice, I'd suggest it strongly. If you ask the question again, I'm going to break out the profanities and point out the fact you are another idiot French Canadian. Figure it out or buy the board. It's a map sensor. It calls for 3 wires. If you can't figure it out, then you are dumb.</TD></TR></TABLE>
LOL
Old Dec 29, 2007 | 02:06 PM
mike_paz17's Avatar
great...i got my car running thanks a ton
