hondata is acting funny is it boost cut?
Old 03-15-2004, 04:12 PM
Nextelbuddy's Avatar
Default hondata is acting funny is it boost cut?
i had my car runed a while ago on the stock motor to about 12-13 psi and we stopped. now my compresion is lower and i am running a test pipe and i noticed my boost goes higher to about 15-16 psi and it was fine but lately i have been hitting what feels like boost cut or something. when im hitting full boost the motor will cut out and my CEL will flash for a second and go away if i turn the boost down back to about 12 psi it doesnt do it anymore but when i turn the boost back up to about 15 psi ill hit that CUT again and the CEL will flash for a split second and go away.
does anyone think my hondata is doing this? my tuner is out of town and i cant ask him but i think he might have programmed my hondata to cut out if i spiked to a certain boost level coudl this be true?
Old 03-15-2004, 04:14 PM
grndcont's Avatar
ya, i think your hitting the cut.
Old 03-15-2004, 04:19 PM
Silverbeast's Avatar
yep that would be the boost cut.
Do you have a stock map sensor or a GM?
Old 03-15-2004, 04:23 PM
Moderator
TheShodan's Avatar
Yeah. Happened to me. Boost cut
Old 03-15-2004, 04:26 PM
Default Re: (TheShodan)
i am running the gm 3 bar map sensor... my tuner never told me he put boost cut on my hondata s200b..... any one else knwo if this could be it?
Old 03-15-2004, 06:13 PM
Default Re: (nextelbuddy)
bump
Old 03-15-2004, 06:24 PM
DaX
DaX's Avatar
I would go with what Silverbeast says, he is a Hondata dealer.
Old 03-15-2004, 06:42 PM
TurboTegB18c's Avatar
Default Re: (DaX)
definately boost cut.
Old 03-15-2004, 07:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">i am running the gm 3 bar map sensor... my tuner never told me he put boost cut on my hondata s200b..... any one else knwo if this could be it?</TD></TR></TABLE>
It should be the boost cut, however i have seen a car where it was actually faulty map sensor wiring.
More than likley it's a boost cut, sometimes when you switch to the 3 bar map from the stock map it's easy to forget to reset the boost cut for more than 11 psi.
Old 03-15-2004, 07:12 PM
5thgencivic's Avatar
Default Re: (Silverbeast)
What code do you guys throw for boost cut. if any of you have jumped it after throwing the CEL? I hit it and pulled the code and it showed one that wasn't even listed... just curious.
Old 03-15-2004, 07:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast &raquo;</TD></TR><TR><TD CLASS="quote">
More than likley it's a boost cut, sometimes when you switch to the 3 bar map from the stock map it's easy to forget to reset the boost cut for more than 11 psi.</TD></TR></TABLE>
well im not sure whats happening then because i am running 13 psi no problem but when i boost 15 psi it does it. and both psi levels are above 11psi.
what exactly is this boost cut? what does it really do is it bad for the motor?
Old 03-15-2004, 07:42 PM
m R g S r's Avatar
I think its like the rev limiter, it either cuts spark or fuel.
Old 03-16-2004, 04:34 AM
Default Re: (m R g S r)
bump
Old 03-16-2004, 05:12 AM
If you have the 3 bar map sensor, your tuner could have very well put in a 13psi cut, or any cut for that matter to keep things safe or at the level he tuned it at.
The other thing to do is to datalog the run and see what code it's throwing, Hondalogger will show that.
Old 03-16-2004, 05:47 AM
oh ok no problem... what is it exactly that the hondata does that causes this though. is it fuel cut? spark cut? all dependent on that set boost level?
Old 03-16-2004, 07:17 AM
fuel cut
Old 03-16-2004, 08:09 AM
ladysman's Avatar
Default Re: (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">fuel cut</TD></TR></TABLE>
Right on. Do you have a way to send me the Hondata File? I can tell you from there if it is on.
Sorry if someone already posted this but I don't have a chance to read all the posts.
Old 03-16-2004, 08:29 AM
Default Re: (ladysman)
sorry i do have a way to get the file. its all good if its what you guys say it is im sure thats what it is then. ill know for sure next week when my tuner gets back from vacation and tunes my car again
Old 03-16-2004, 08:44 AM
ladysman's Avatar
You'll know dude. It is basically the same as a rev limiter. The car will fall on it's nose.
Old 03-16-2004, 09:28 AM
Yep, just flat out dies pretty much. Almost like the motor just shuts down completely for a moment.
Old 03-16-2004, 09:39 AM
exactly thats what it does. the first time it happened it scared the **** out of me lol.
why doe the CEL flash quickly and then go away when it happens though
Old 03-16-2004, 09:43 AM
The CEL should be for the MAP sensor
Old 03-16-2004, 09:46 AM
Scared the crap out of me too, lol. Mine would throw a code that wasn't even listed in the helms when I would hit boost cut, so I dunno. It was 30 something, can't remember.
Old 03-16-2004, 09:57 AM
Should be Code 3 or 5
BLWNB16A@11psi
06-22-2005 08:27 PM
60-1teg
06-19-2004 03:00 PM
tgrace
10-07-2003 01:52 PM
MayhemSi
09-17-2003 08:51 AM
Quick Reply: hondata is acting funny is it boost cut?
