in-line fuel pump....
Old Jun 21, 2002 | 10:35 AM
CM-R's Avatar
Default in-line fuel pump....
Is the airtex in-line fuel pump that came with the drag 3 kit sufficiant enough for 10-12 pounds of boost with rc 440cc injectors?...I'll be going hondata 2b and i will have to remove my vortech FMU and i might just leave in the in-line fuel pump....Do i need to get a walbro in-tank 255 iph fuel pump or is the in-line just as good??....The guys at DSR tuning said that it was good enough....Will i loose any hp's from not running a intank fuel pump??....thanks in advance
Old Jun 21, 2002 | 11:06 AM
newsense's Avatar
New User
Default Re: in-line fuel pump.... (CM-R)
It should hold 10-12 pounds of boost easily but If I were you I would just get the walbro anyway.
Old Jun 21, 2002 | 11:34 AM
CM-R's Avatar
Default Re: in-line fuel pump.... (newsense)
I'll just keep that in-line for a while....then later i'll get the walbro...
KrispyKreme
Apr 20, 2005 03:52 PM
tolowhb
May 11, 2003 08:46 PM
PUREVIL
May 8, 2003 06:55 PM
2K1NBGSR
Feb 25, 2002 02:31 PM
Teluan
Sep 4, 2001 08:56 PM
