compressor tap
Old May 17, 2002 | 06:18 PM
GruvyTune's Avatar
New User
Default compressor tap
I got a new turbo for my car. Its got a T04E garrett compressor housing but the compressor is lacking a nipple fitting like my T04B had.
What should I do? Do I have to tap the compressor for my boost controller/wastegate? or is it easier to just tap the intake pipe going to the throttle body?
Old May 17, 2002 | 06:24 PM
intekragsr's Avatar
Default Re: compressor tap (GruvyTune)
tap intercooler piping.
Old May 17, 2002 | 09:18 PM
GruvyTune's Avatar
New User
Default Re: compressor tap (intekragsr)
so then what do you do when you hook up your boost controller. The side port of the wastegate is supposed to go to the compressor isn't it, or do you just T off a tap on the intake pipe and run one to the wastegate sideport and the other to the boost controller solenoid?
Old May 17, 2002 | 09:26 PM
Quaalude's Avatar
this is what i am going to do with avcr...use to have a turbonetics turbo but now i have the garrett which doesn't have the port on the compressor housing....going to tap the ic piping for the boost source
Old May 18, 2002 | 05:44 AM
GruvyTune's Avatar
New User
Default Re: compressor tap (Quaalude)
has anyone here actually tapped their compressor housing? Seems like it would be a bitch to drill through.
Old May 18, 2002 | 06:26 AM
intekragsr's Avatar
why not just do what i did. TAP THE INTERCOOLER PIPING like the instructions will say to do on the apexi and greddy instructions. Yes, you have to buy a brass t and hook both ports up to the intercolller pi[ing
s4yama
Nov 6, 2008 12:01 AM
Alpinestar03
Aug 4, 2008 09:51 AM
hotrod99
Jun 13, 2007 04:01 AM
HamiltonRex
Jan 2, 2006 12:12 PM
95hatchfire
Jan 30, 2005 10:45 AM
