Vacume at Compressor for Wastegate?
Old Jan 1, 2006 | 08:15 PM
HamiltonRex's Avatar
Default Vacume at Compressor for Wastegate?
Ive decided that im going to get my vacume for my wastegate at my Compressor.. Less chance of spiking/creep. I will adjust with my boost controller for any drop in pressure due to it seeing the boost earlier!
Now.. I have a Garrett T3/T40e Turbo.. 57trim .63ar and theres no fitting or port on the compressor for a vac fitting.
Since i dont feel comfortable drilling/tapping my turbo. Could i put it in the charge piping like 2" away from the outlet of the compressor?
TYIA!
Old Jan 1, 2006 | 09:02 PM
Boilermaker1's Avatar
I don't see how 2" is going to make a difference. 2" down the pipe may be .0000001 PSI less or something minute. As long as its before the IC, I'd say you're going to read the same pressure in the mouth of the charge pipe as you would tapping the compressor housing. You will obviously have to correct it with what you want the manifold to see, but it looks like you got a handle on that.
Old Jan 1, 2006 | 09:22 PM
Boostfed's Avatar
New User
Try one of these sir
http://www.atpturbo.com/Mercha...e=BCS
Old Jan 1, 2006 | 09:24 PM
D@nnY's Avatar
the magic trick will be getting vacuum out of the turbo..... maybe if it spun backwards?
Old Jan 2, 2006 | 04:57 AM
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">the magic trick will be getting vacuum out of the turbo..... maybe if it spun backwards?</TD></TR></TABLE>
Damn you guys! You know what i mean
Thanks boostfed, that looks like it will do the trick
Old Jan 2, 2006 | 08:11 AM
yee SERIOUS's Avatar
hmmm i might need one of those too.
Old Jan 2, 2006 | 08:44 AM
99_GS-T's Avatar
If you use pre-intercooler, you'll have boost drop issues due to the pressure drop increase of the intercooler as the revs rise.
Old Jan 2, 2006 | 11:57 AM
Default Re: (99_GS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">If you use pre-intercooler, you'll have boost drop issues due to the pressure drop increase of the intercooler as the revs rise.</TD></TR></TABLE>
Thats why im going to get the vac for the boost gauge from the IM.. and use my boost controller to tune
Old Jan 2, 2006 | 12:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">Try one of these sir
wish i knew about them earlier. i drilled and tapped my t3t67, but oh well, thats the way i have always done it.
Old Jan 2, 2006 | 12:05 PM
Dee's Avatar
Dee
Default Re: (boostedcivicsir)
I had two bungs added to my IC piping when it was welded together. -4 fitting for the AVC-R and a -6 for the bottom WG port.
Old Jan 2, 2006 | 12:12 PM
turbotime's Avatar
why not read vacuum and boost at the manifold?
The readings youll get at the compressor housing will be off cause there is like a 2psi pressure drop thru the ic.
Also you can read boost AND vacuum from the manifold
s4yama
Nov 6, 2008 12:01 AM
96ex
Jun 30, 2005 05:33 AM
Accurate GS-R
Oct 9, 2004 06:51 AM
pissedoffsol
Mar 26, 2004 07:04 PM
GruvyTune
May 18, 2002 06:26 AM
