compressor housing vacumm
Old Jun 11, 2007 | 07:47 PM
hotrod99's Avatar
Default compressor housing vacumm
the vacumm tap on the compressor housing was originally hooked up to the side of the wastegate,but when you install a manual boost controller you hook the MBC up to the side of the wastegate. My question is what do you do with the vacumm source on the turbo?
Old Jun 11, 2007 | 08:20 PM
numbnuts22715's Avatar
doesnt the mbc go between the wastegate and compressor housing?
From housing to boost controller, then from boost controller to wastegate?
Boost controllers have 2 vacuum ports.
Old Jun 12, 2007 | 09:13 AM
hotrod99's Avatar
Default Re: (numbnuts22715)
I thought the that the bottom port of the MBC goes to the wastegate,and the side port goes to vacumm source on the intake manifold
Old Jun 12, 2007 | 09:24 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">I thought the that the bottom port of the MBC goes to the wastegate,and the side port goes to vacumm source on the intake manifold</TD></TR></TABLE>
NO, you need that source to come BEFORE the TB. Hook the BC up inline of what you have. ie: compressor housing&gt;BC&gt;WG.
Old Jun 12, 2007 | 09:39 AM
TiAL's Avatar
Default Re: (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
NO, you need that source to come BEFORE the TB. Hook the BC up inline of what you have. ie: compressor housing&gt;BC&gt;WG.</TD></TR></TABLE>
correct, you just delay or bleed signal coming from the compressor housing to the bottom port of the wastegate so it opens later
Old Jun 12, 2007 | 01:07 PM
hotrod99's Avatar
Default Re: (TiAL)
ok so I hook the bottom of the MBC to the wastegate,then the vacumm source coming from the comp.housing goes to the side port on the MBC?
Old Jun 13, 2007 | 03:53 AM
i my honda
Global Mod
Yeah, if thats how your BC instruction say it should be hooked up. (side port to vacuum source and bottom port to WG)
Old Jun 13, 2007 | 04:01 AM
Flashmn's Avatar
considering a wastegate doesnt work with vacuum...
standbackimapro
May 30, 2006 05:22 AM
CBURKE
May 23, 2006 06:02 AM
Nextelbuddy
Mar 26, 2004 01:20 PM
1fstevo
May 30, 2002 12:17 AM
GruvyTune
May 18, 2002 06:26 AM
