Boost source on compressor housing..
Old Jul 28, 2008 | 01:58 PM
Alpinestar03's Avatar
Default Boost source on compressor housing..
Im in a predicament on where the best boost source would be on the compressor housing. I have a hole already tapped for a nipple (red arrow) should i use that or should i drill and tap a spot for a nipple on the end of the outlet (green arrow). BTW im using this for my WG.
Any and all help is appreciated..
Old Jul 28, 2008 | 03:56 PM
VTECth1s's Avatar
Default Re: Boost source on compressor housing.. (Alpinestar03)
I commonly see the vacuum port where the green is pointed. Turbonetics and a few other turbo's have it there as well.
Old Jul 28, 2008 | 04:35 PM
2point2's Avatar
try them both and see which one works out better.
Old Aug 4, 2008 | 12:54 AM
AdamB18C1EK's Avatar
Default Re: (2point2)
mine is green
Old Aug 4, 2008 | 04:14 AM
Mikey3000's Avatar
i dont think it matters.
Old Aug 4, 2008 | 04:43 AM
Tjabo's Avatar
Default Re: Boost source on compressor housing.. (Mikey3000)
Shouldn't either of these locations only see boost? It seems like significant vacuum can only exist between the throttle plate and the intake valves. . .
Old Aug 4, 2008 | 09:51 AM
TheShodan's Avatar
Moderator
Default Re: Boost source on compressor housing.. (Tjabo)
The one you have tapped should be sufficient.
hotrod99
Jun 13, 2007 04:01 AM
boost4life
May 14, 2007 05:55 PM
standbackimapro
May 30, 2006 05:22 AM
95hatchfire
Jan 30, 2005 10:45 AM
