car wont run after walbro install
Old 06-19-2005, 12:21 PM
VspecSiR's Avatar
Default car wont run after walbro install
installed a 190lph walbro pump in my 00' civic si w/greddy turbo kit (310cc injectors and blue box) First off i thought the walbro pump was supposed to fit faily easily like everyone said, I found that it didn't just drop in as easy as everyone says. I eventually got the pump in, but still wonder why it was so difficult to install.
anyhow, i start my car up and nothing, i cant even get the car to idle. for 5 seconds. Now I dont' have an adjustable FPR, should I get one? could the fuel pressure be too high?
Old 06-19-2005, 12:27 PM
dc2legend's Avatar
Default Re: car wont run after walbro install (VspecSiR)
Can you hear the pump come on when you turn the key to the ON position? When I did mine it didn't turn on the first couple times, it was weird. Then it just worked..
Old 06-19-2005, 12:33 PM
VspecSiR's Avatar
Default Re: car wont run after walbro install (dc2legend)
yes, i turn the key on and I can hear the pump prime
Old 06-19-2005, 12:36 PM
reaction360's Avatar
i'm not sure what else could be the problem but the pump should only have taken u like 10-15 minutes tops to install. and it does go in pretty easily. make sure the pump is correct for ur car. and is a 190lph
Old 06-19-2005, 12:55 PM
s2kdre's Avatar
Default Re: car wont run after walbro install (reaction360)
if you're low on gas you might have the wrong pickup filter on the pump
Old 06-19-2005, 01:34 PM
s2000june's Avatar
wrong pump? i would take it back.. and get the Walbro 255 HV Fuel Pump.
Old 06-19-2005, 02:47 PM
dc2legend's Avatar
Default Re: (civicrida3)
He doesnt really need a 255 HP for his setup.
If the pump is priming, I would check to see if maybe the pickup fell off. You know for sure is on.
Old 06-19-2005, 04:42 PM
onesikcivic's Avatar
if you installed it correctly it should be fine, unless you did something else, i just installed my walbro 255 on my civic and it wasnt to back even though i had to drop the tank, but it worked fine, maybe you go tthe wrong pump?
Old 06-19-2005, 06:01 PM
gsrboost's Avatar
Default Re: (onesikcivic)
Do you have fuel pressure at the rail?
Old 06-20-2005, 01:29 AM
s2000june's Avatar
Default Re: (dc2legend)
he doesnt but mine as well put it in .. cause hell proll end up going bigger and better anyway
Old 06-20-2005, 01:39 AM
85's Avatar
Default Re: (gsrsp33d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrsp33d &raquo;</TD></TR><TR><TD CLASS="quote">Do you have fuel pressure at the rail?</TD></TR></TABLE>
yeah after checking if the pump is on (can you hear it) i would check the pressure at the rail. as for the fuel pressure reg, i would recommend a pressure sensitive regulator but don't worry about that until you can get the car running.
Old 06-20-2005, 07:18 PM
VspecSiR's Avatar
Default Re: (hks85)
sorry, i dont have a gauge to tell if i have pressure @ the rail. I guess I should get that before i try and install the pump again.
Ek4 life
15
07-17-2008 05:14 PM
RunninEg6
14
03-06-2008 07:17 AM
luti
10-29-2003 01:48 AM
preluder
08-29-2003 07:56 AM
AlphaKennyWun
03-31-2002 06:20 PM
Quick Reply: car wont run after walbro install
