Oil pressure problem
Old Jun 19, 2005 | 10:30 PM
j-robsDA's Avatar
Default Oil pressure problem
Just got my new motor put in and tuned. Now my oil pressure gauge (mechanical) shows what looks to be fairly low oil pressure. I am at 5psi at warm idle and at 3000rpms I am at 36psi. This seems a little low to me. At 6000rpms it is at 65psi which to my knowledge is plenty. Can anyone comfirm what the helms says for warm idle and 3krpms pressure? My oil feed line is a little larger than my old one I picked up from http://www.fast-turbo.com and was wondering if a larger feed line would lower pressure at all. BTW this is a fully built b16 by JG with only 100 miles on it and a brand new oil pump. Could it be my bearings and the way they built the motor?
Old Jun 19, 2005 | 10:46 PM
s2kdre's Avatar
Default Re: Oil pressure problem (j-robsDA)
you should be at 5-10psi on a hot idle and on an ls at wot maybe 50-60
Old Jun 19, 2005 | 10:47 PM
s2kdre's Avatar
Default Re: Oil pressure problem (jdmhonda)
do you have an ls?
Old Jun 20, 2005 | 06:31 AM
j-robsDA's Avatar
I have a fully built b16 for boost.
Old Jun 20, 2005 | 07:39 PM
j-robsDA's Avatar
bump
ProjectBB6
Sep 16, 2009 02:18 PM
Preludepradit
Oct 12, 2007 01:57 PM
thomas188
Jan 12, 2007 11:23 AM
Harassing Herbs
Mar 16, 2004 05:09 PM
IntegD
Jan 8, 2003 09:31 PM
