Block Guards
Block Guards
i have a built b18b (JE pistons, Eagle Rods, ACL Bearing, Crower STG II Cams)with stock sleeves. it has a garret 57 trim on it and i plan to run 20+ psi and i have all te supporting mods as well. i was jus wondering if a block guard would be a wise investment and if they are as easy to put in as they sound.
Ek Forever y0!
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">sleeve it b4 boosting 20psi...the max i would ever boost a b series with stock sleeves is 8psi or lower</TD></TR></TABLE>
All depends on the turbo man. Differen't turbos are going to make different HP at different levels of boost.
stock d's are good for ~200 whp
im tuning it with crome by j-k tuning. ive asked around and i was told the b18bs are rock solid when it comes to boost and others on this sight say the stock sleves can handle 20 psi....
Guest
Posts: n/a
Re: (civicb18Tkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb18Tkid »</TD></TR><TR><TD CLASS="quote">im tuning it with crome by j-k tuning. ive asked around and i was told the b18bs are rock solid when it comes to boost and others on this sight say the stock sleves can handle 20 psi....</TD></TR></TABLE>
somebody gassed you up
been there done that
Re: (civicb18Tkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb18Tkid »</TD></TR><TR><TD CLASS="quote">ok then well im plannin to put down about 435 hp lol stock sleeves ok for the summer?</TD></TR></TABLE>
i would go ahead and sleeve to be safe
ok well im going to get it tuned tuned and grab a spare block and sleeve it cause i heard that installin block guards can be a bitch to install and create hot spots
JDMCRX
07-16-2003 11:08 AM
DamonBoost
12-13-2001 08:46 AM
