boost gauge fluttering, why?
Old Apr 20, 2004 | 06:05 AM
quickergixxer's Avatar
Default boost gauge fluttering, why?
i recently turned boost up to 15 psi and the boost gauge flutters between 13-16 wont stay still?
i have a 7.5 lbs spring is it running out? or do i have a boost leak? has anyone ever had this problem?
thanks
Old Apr 20, 2004 | 09:11 AM
J337_UNIT's Avatar
Default Re: boost gauge fluttering, why? (quickergixxer)
sounds like your boosting too much on that spring.. your gonna need a stiffer spring
Old Apr 20, 2004 | 05:23 PM
Default Re: boost gauge fluttering, why? (J337_UNIT)
i was kinda thinking the same but i have never ran a wg spring out before so dont know what happens?
Old Apr 20, 2004 | 05:37 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickergixxer &raquo;</TD></TR><TR><TD CLASS="quote">i was kinda thinking the same but i have never ran a wg spring out before so dont know what happens?</TD></TR></TABLE>
just get a 12 psi spring or something like that and that flutter should go away
Old May 13, 2004 | 04:56 PM
just wondering if anyone here has had this problem
thanks
Old May 13, 2004 | 04:59 PM
SeanEF's Avatar
The fluttering is boost going back into the compressor....it happens when you have the bov adjusted to tight
Old May 13, 2004 | 05:01 PM
SeanEF's Avatar
Default Re: boost gauge fluttering, why? (SeanEF)
My bad i thought you meant it fluttered when you let off the gas...definitely sounds like you need a stronger spring or adjust the spring tighter. you are boosting above the limit of the bov
Old May 13, 2004 | 05:04 PM
i mean wg spring, when we had it on the dyno i messed with the bov adjester and the problem didnt seem to change, maybe i should adjust it more
Old May 13, 2004 | 05:53 PM
RotiEatter's Avatar
Ditto
I don't know if this is 100% true or not, someone told me this could be caused by the wastegate bolts not being tight. Worth a shot.
Old May 13, 2004 | 05:55 PM
Default Re: boost gauge fluttering, why? (RotiEatter)
thanks i will check to make sure everything is tight
b20beast83
Jan 30, 2010 04:49 PM
91integraLSVTEC
Oct 21, 2009 11:09 AM
pjr710
May 22, 2009 10:22 AM
radeon
Jul 9, 2007 03:22 AM
I Gotta Question
Jan 18, 2004 12:41 PM
