boost!!!!!!!!
Old Apr 30, 2007 | 08:35 AM
peter_vang's Avatar
Default boost!!!!!!!!
alrite, i have a STOCK 92 civic si, and i put a turbo t3 turbo kit on it, but i was wondering, how much boost would be able to get out of it WITH OUT a TUNE...???? i don't have any injectors, nor fuel pump, let me know!!
Old Apr 30, 2007 | 08:47 AM
eshlil's Avatar
Default Re: boost!!!!!!!! (peter_vang)
I recommend getting injectors and tuning. but you can run an fmu and missing link and on your motor prob around 7psi.
Old Apr 30, 2007 | 09:21 AM
Topdawgg's Avatar
why bother if you are going to do it HALF ASSED
actually, thats not even half assed...
dont bother
Old Apr 30, 2007 | 09:45 AM
White Smoke's Avatar
i my honda
Global Mod
7PSI MAX with an FMU, thats not all that safe but it works.
Old Apr 30, 2007 | 11:21 AM
ragethemachine86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peter_vang &raquo;</TD></TR><TR><TD CLASS="quote">alrite, i have a STOCK 92 civic si, and i put a turbo t3 turbo kit on it, but i was wondering, how much boost would be able to get out of it WITH OUT a TUNE...???? i don't have any injectors, nor fuel pump, let me know!! </TD></TR></TABLE>
DSM injectors 50$
Walbro 255lph 90$
Crome/Uberdata 0$
then find a tuner...
Old Apr 30, 2007 | 06:12 PM
92gisser's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">why bother if you are going to do it HALF ASSED
dont bother</TD></TR></TABLE>
x2
Old Apr 30, 2007 | 06:27 PM
turbo16's Avatar
Default Re: (92gisser)
get some injectors fuel pump and run crome its free
then find a tuner
be worth it in the long run!!!
Old Apr 30, 2007 | 06:39 PM
BrockNB's Avatar
this thread made me lol a bit.
1st off understand that Motor + Boost + OEM Parts + No Tune = EXPLOSION.
get the parts that rage stated and a tune. Even if your not spending hours of dyno time. at LEAST get a street tune and then your laughing. 5-8psi daily will be no prob on that size of turbo pending your not holding redline for extended periods of time.
Old May 1, 2007 | 10:56 AM
peter_vang's Avatar
Default Re: boost!!!!!!!! (BrockNB)
thanks thanks!! does crome need a aftermarket ecu or anything like that, not really familar with this stuff yet!!
Old May 1, 2007 | 11:07 AM
i my honda
Global Mod
You already have a P28 and are OBD1 so all you need is to get your ecu chipped and you can run crome. Most places change like 60$ to chip the ECU and tuning is generally about 150 or so an hr to tune. I will probably be like 200-300$ for a full tune since you setup is so simple.
You will need to get some injectors and a fuel pump. Even if you do go with the FMU you will def need a new fuel pump.
Old May 1, 2007 | 11:12 AM
doood's Avatar
been there done that
Default Re: boost!!!!!!!! (White Smoke)
http://www.phearable.net/tech/....html
Old May 1, 2007 | 03:24 PM
peter_vang's Avatar
sweet! thanks !! anyone know any places around the lancaster that'll tune cars...no further than phillly please!
Old May 1, 2007 | 03:30 PM
envee's Avatar
https://honda-tech.com/zerothread/1347699
burks
Apr 30, 2007 02:13 PM
b18c1wes
Oct 2, 2004 05:45 AM
honkey2fly
Apr 22, 2004 11:50 AM
spl_nut
Apr 13, 2003 10:10 PM
AlphaKennyWun
Dec 22, 2001 08:27 AM
