Wierd Afr issue
Old May 1, 2007 | 05:04 AM
Boosted Chemist's Avatar
Default Wierd Afr issue
Ive been tuning my car for partial throttle for the last couple of weeks on my way home from work. So i get it dialed in pretty good high 13-low 15s from 19"-5". All of a sudden the last couple days my car has been reading low 11s and even 10 at idle. I havent changed a thing. Its gotten a little colder out (10 degrees) Any idea what could cause this.
Im tuning with crome.
also posted in pgmfi.org
THanks
Old May 1, 2007 | 05:06 AM
miller's Avatar
Default Re: Wierd Afr issue (Boosted Chemist)
Have you messed with a the air temp comp
Old May 1, 2007 | 05:08 AM
Default Re: Wierd Afr issue (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">Have you messed with a the air temp comp </TD></TR></TABLE>
No ive left all the extra tables alone minus idle speed. Ive only tuned off the tables
Old May 1, 2007 | 03:47 PM
blackeg's Avatar
does the car drive the same? check your plugs....this is a longshot but it happend to me before- check your wideband sensor, maybe it needs recalibration or is old
WihaSi
Apr 14, 2007 05:42 PM
93JDMB18C
Nov 2, 2006 02:03 PM
Chinchilla
Sep 7, 2004 07:29 AM
jeux
Aug 6, 2004 03:36 PM
chronodyne28
May 3, 2004 12:07 PM
