STOCK LS..HOW MUCH BOOST ??
Old Apr 29, 2007 | 09:08 PM
burks's Avatar
Default STOCK LS..HOW MUCH BOOST ??
I'm running an xspower t3.t4, 450 injectors, walboro fuel pump, victor x manifold..custom exhaust, and tunned ecu...Whats the max boost i should run?? I'm using a sidemount intercooler..my car has 160k but but in perfect condition..engine well maintained..i wanted to do 8psi..i didn't know if thats to much..?I want to tune this week so let me know..thanks..all feedback is appreciated and noted..I'm probably gonna just do 7 unless someone out there with a turbo ls can tell me otherwise..and i don't want to BLOW my engine..daily driver.THANKS
Old Apr 29, 2007 | 09:12 PM
doood's Avatar
been there done that
Default Re: STOCK LS..HOW MUCH BOOST ?? (burks)
250-300whp with however many psi that crappy turbo needs
wouldnt push it much more than that with those injectors
Old Apr 29, 2007 | 09:33 PM
tony n.'s Avatar
Default Re: STOCK LS..HOW MUCH BOOST ?? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">250-300whp with however many psi that crappy turbo needs
wouldnt push it much more than that with those injectors</TD></TR></TABLE>
Old Apr 29, 2007 | 09:46 PM
FaceTuned's Avatar
15 lbs itll run fine.
Old Apr 30, 2007 | 12:02 AM
BEST1TUNING.COM's Avatar
Default Re: (FaceTuned)
your injectors are going to hold you back just a bit but u can get about 300 out of your current setup. Im in malvern if you need tuning. I just did an Ls in king of prussia last week. If you need something as far as tuning shoot me an e-mail.
Old Apr 30, 2007 | 03:02 AM
a1320honda's Avatar
Default Re: (BEST1TUNING.COM)
Im doing 11 right now on a bone stock ls. 11 is cause i dont have anything other than the stock map sensor. On a good tune with the dsm injectors 300 is gonna be maxin it out with high fuel pressure. Like i said, with 450's thats gonna be your biggest limit. So if you have a good tuner, on a stck map, dont go over 11. i tried rinning 15 before i knew about the map sensor issue and was lifting the head due to high cylinder pressure cause by excessive timing.
Old Apr 30, 2007 | 04:15 AM
Bioinfomatic's Avatar
Default Re: (a1320honda)
Best1Tuning is the best I had my integra tunned by them, they are great.
Old Apr 30, 2007 | 10:31 AM
Default Re: (Bioinfomatic)
^ Thanks kris you need to give me a call by the way
Old Apr 30, 2007 | 01:05 PM
oxSLEEPERxo's Avatar
have you thought about getting a front mount intercooler?
Old Apr 30, 2007 | 02:13 PM
SOHC_MShue's Avatar
Default Re: (oxSLEEPERxo)
why make 2 threads?
Jack_Havoc
Oct 14, 2008 07:50 AM
jlfrnce
Sep 5, 2007 12:54 PM
trex352
Jun 6, 2007 09:04 PM
mrdeadman
Jul 15, 2005 10:41 AM
Chip398193
Nov 19, 2001 10:55 AM
