is this bock sleeved????????
Old Jan 27, 2008 | 07:54 PM
mannyman2's Avatar
Default is this bock sleeved????????
it was sleeved. thanx guys
Modified by mannyman2 at 12:44 AM 2/23/2008
Old Jan 27, 2008 | 08:08 PM
MbzTech's Avatar
Default Re: is this bock sleeved???????? (mannyman2)
It looks like it has stock sleeves to me...
Old Jan 27, 2008 | 08:10 PM
G2K's Avatar
G2K
Looks like if definatly has a block guard. It may have some sort of drop in replacement sleeve. But its hard to tell. I do know alot of machine shops back in the day use to use drop in sleeves. They are not as strong as something like Golden Eagle or Darton.
Old Jan 27, 2008 | 08:14 PM
mannyman2's Avatar
Default Re: is this bock sleeved???????? (G2K)
right, i could tell it has a block gaurd. but sleeves looked a lil thicker??? more opinions would be good
Old Jan 27, 2008 | 08:44 PM
riceball777's Avatar
stock sleeves
stock sleeves have 2 layers and all 4 cilindards are 1 piece. iron on the inside and aluminum on the outside. after market sleeves are all iron and there are 4 seperate sleeves
Old Jan 27, 2008 | 09:03 PM
viet_boi_racin's Avatar
Default Re: is this bock sleeved???????? (riceball777)
stock sleeves with blockguard.
Old Jan 27, 2008 | 09:24 PM
Schister66's Avatar
Man U FTW
Stock sleeves with a block guard. You can tell by the fact that the sleeves appear to have 2 layers to them. Also, you can see that all of the sleeves are connected as one piece. Aftermarket sleeves come as individual pieces
Old Jan 27, 2008 | 09:30 PM
Garage 808 Hatch's Avatar
they look like JG sleeves to me, OEM ductile iron sleeves are no where near that thick. look at the steel Vs. aluminum thickness there.
those are the pressed in ductile iron liners.
Notice that the iron part "darker" material touch in the OE post. a stock block will have aluminum material between the ductile iron all the way around
like this
Old Jan 27, 2008 | 09:34 PM
Schister66's Avatar
Man U FTW
^^The sleeves are made of 2 materials; the outer of which actually attaches to the adjacent sleeve. Aftermarket sleeves do not have this Siamese sleeve design, but Honda does
Old Jan 27, 2008 | 09:40 PM
Default Re: (Schister66)
yes, but the older style sleeves are that way, they bore out the stock sleeves, and some of the aluminum to make room for a thicker "and stronger" ductile iron sleeve.
they were called ductile iron Liners
Old Jan 27, 2008 | 09:43 PM
Schister66's Avatar
Man U FTW
Touche my friend! I didnt see the picture before making my post or i would have changed my tune a little bit. From what i had ever seen, only stock sleeves had the Siamese sleeve design. All of the sleeves nowadays (from what i can recall off the top of my head) are separate, but butt up against one another.
I think you may be on to something
Old Jan 27, 2008 | 09:50 PM
ya, JG, and i believe darton had this style and maybe a coule others, until the started doing the solid deck style that is more common now
Old Jan 27, 2008 | 09:55 PM
Schister66's Avatar
Man U FTW
Well...now i know
Old Jan 27, 2008 | 10:02 PM
Old Jan 28, 2008 | 05:45 AM
Schister66's Avatar
Man U FTW
^^ LOL...my thoughts exactly
Old Jan 28, 2008 | 08:38 AM
1dumbscreenname's Avatar
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
hahaha, good info guys!!!
Old Jan 28, 2008 | 10:13 AM
CerealKiller's Avatar
jg sleeved with block guard. get your money back.
Old Jan 28, 2008 | 03:17 PM
93supercoupe's Avatar
Default Re: is this bock sleeved???????? (CerealKiller)
thats what the guy is advertising, making everything true and all good
Is there any reason he should get his money back?Is it a bad design?I dont understand what ur post means.
Old Jan 29, 2008 | 07:05 AM
Default Re: is this bock sleeved???????? (93supercoupe)
one of many lower quality sleeves and machine work. (of course someone will defend jg) but based with what I seen in their work, I was not satisfied. Again it's my opinion.
Old Jan 29, 2008 | 03:36 PM
mannyman2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">they look like JG sleeves to me, OEM ductile iron sleeves are no where near that thick. look at the steel Vs. aluminum thickness there.
like this
thank you. thats what i was trying to point out. the sleeve was a bit thicker than most OEM. I thank you for not posting the usual "its oem with blockgaurd" and looking at the pics and making a sound wise answer. I almost gave this up as a regular block.
And I picked this up for a few hundred bucks, and it has gsr crank, eagle rods, and forged low comp pistons. So its all good. Garage808hatch, u have pm
Old Jan 29, 2008 | 05:44 PM
Hybrid_Coupe's Avatar
I havent had a problem with my jg sleeves, my buddy did. its a hit or miss thing. Not saying all their work is awesome or anything, but i personally have not had a problem. Again...its only my opinion. I say, if you picked it up cheap...give it a shot. Thats why i used a jg block lol.
Old Jan 29, 2008 | 06:59 PM
blinx9900's Avatar
JG sleeves arent real sleeves imo, he just bores out the stock iron, and a little past the aluminum then presses in a thicker iron insert, i think a company called LA sleeve sells the thicker stock iron inserts not 100% on that part, but yeah, yet another reason i dont like JG and yes im a member of the "official jg is a horrible person and business bandwagon"
Old Jan 29, 2008 | 08:53 PM
AllmotorEH2's Avatar
like this
What block is it? because a B20 block the iron parts of the sleeve touch in the middle FACTORY and do not have the aluminum between cylinders
Old Jan 29, 2008 | 09:08 PM
mannyman2's Avatar
Default Re: (AllmotorEH2)
the one i have is b18b
and yes i got it fairly cheap. will boosr on it maybe ... or just go allmotor to be on the safe side.
ceearexx
Jan 30, 2013 09:33 PM
monster_c
36
Feb 25, 2012 04:27 AM
DCtooD
Jul 28, 2010 07:43 PM
Boostn B20
Aug 20, 2008 03:28 PM
KeyserSoze
May 14, 2005 09:40 AM
