block sleeving
Old Jul 29, 2008 | 06:04 AM
Boostn B20's Avatar
Default block sleeving
lets say for example u sleeve an 81 mm block to an 84 mm, and then wanna boost it. work with me here, im gonna try and draw it out...u have a certain amount before u max out the sleeve???so if u sleeve it to an 84mm (the sleeves get thinner the bigger you go), wouldn't this be just as risky as say boosting a stock 81mm????someone tried explaining this theory to me, kinda got it, but wondering if anyone can help clear up a bit more? preferably someone from golden eagle...
Old Jul 29, 2008 | 07:12 AM
SpoolnG2's Avatar
Default Re: block sleeving (Boostn B20)
The difference is the material the sleeves are made of. I dont know the exact materials they are made of, but I do know the sleeves golden eagle, benson, erl, etc use have a greater strength......this is what the difference is between using a stock sleeve at 81mm vs a aftermarket sleeve at 84mm. I believe the aftermarket sleeves are ductile iron.
Old Jul 29, 2008 | 08:04 AM
Boostn B20's Avatar
yea, but, im not sure, the way it was explained to me is, in order to press an 84mm sleeve into a block made for an 81mm, the sleeve becomes much thinner. it was explained, that basically any b series engine made to an 84mm is basically garbage??? personally, all i wanna do is safely boost a 2.0L, but if the risk is greater than the outcome, 1.8L boost will suit me just as well.
Old Jul 29, 2008 | 08:11 AM
thatblkguy's Avatar
whos telling you all this stuff? I hope its not a machine shop.
Old Jul 29, 2008 | 08:26 AM
94delslo's Avatar
Default Re: (Boostn B20)
Going with a 84mm bore is perfectly safe. Yes the sleeves will be thinner but because they are made out of iron they will be ALOT stronger then your stock 81mm sleeves even though they are not as thick. I think anything over 84.5mm or 85mm is the limit. Someone else can chime in that knows for sure. Tony1 said that he only uses 84mm bore in his motors. He also said that you have room to rebuild your engine and bore/hone your sleeves 2 times before they get to thin to where you would have to re sleeve it if you start out at 84mm.
Old Jul 29, 2008 | 11:47 PM
Tony the Tiger's Avatar
The sleeves are not actually thinner... Inner diameter is 84mm, but on a resleeved motor, the entire outer diameter of the sleeve is made out of ductile iron, hence, thicker.
If you go 84mm on a stock sleeve Honda block, then yeah, that is basically garbage for boost because the iron portion of the sleeve becomes paper thin. The outer sleeve on a stock Honda block is basically a fragile aluminum casing.
Old Aug 14, 2008 | 04:52 PM
hatchtegman's Avatar
Default Re: block sleeving (Tony the Tiger)
what should i ask for? when i go to get my blcok sleeved. i have a 94 gsr block. i am using a gt37 or 40 r garret on 84 mm pistons build blcok cams the works tuned and lsd ect
are there any difference in the desings for sleeves im going for 700hp.
;thanks
shane
Old Aug 14, 2008 | 05:38 PM
non-VTEC's Avatar
Default Re: block sleeving (hatchtegman)
if you ship your block to golden eagle they will use their own "made in house" sleeves which work fine.
if you take it to any other machine shop who has done that type of work before chances are they will use darton sleeves.
both are very good qualitly sleeves.
Old Aug 14, 2008 | 06:06 PM
th3pwn3r's Avatar
Default Re: block sleeving (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">The difference is the material the sleeves are made of. I dont know the exact materials they are made of, but I do know the sleeves golden eagle, benson, erl, etc use have a greater strength......this is what the difference is between using a stock sleeve at 81mm vs a aftermarket sleeve at 84mm. I believe the aftermarket sleeves are ductile iron. </TD></TR></TABLE>
Let's not forget about the bracing that after-market sleeves offer. The bracing plays a huge role in the strength of the bottom end(obviously).
Old Aug 16, 2008 | 04:12 PM
Default Re: block sleeving (non-VTEC)
will i recieve my block? or a pre-sleeved block or core as they call it?
Old Aug 16, 2008 | 05:15 PM
blinx9900's Avatar
pretty damn sure a 84mm sleeved block still has thicker walls than an 81mm oem block... and again, material used, bracing etc... all play a major role.
Old Aug 16, 2008 | 05:29 PM
Maxcapacity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchtegman &raquo;</TD></TR><TR><TD CLASS="quote">will i recieve my block? or a pre-sleeved block or core as they call it?
That is something I am also interested in finding out... Cause I spent a good amount of time deburring it and smoothing out any imperfection. Also cleaned&slightly opened up any casting flaws in the oiling for the main's bearings.
My tuner got his block back from G eagle after sleeving and we don't know if it was throught the shipping process or what but by the time it got back the surface for the head had nasty scrape's, nick's and gouges on the edge near the oil passages.
Old Aug 19, 2008 | 11:00 AM
i hope that doesnt happen to myblock.
i already payed to have it hottanked and i have recorded the serial numbers and such
goodluckm
Old Aug 19, 2008 | 03:29 PM
Golden Eagle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">The difference is the material the sleeves are made of. I dont know the exact materials they are made of, but I do know the sleeves golden eagle, benson, erl, etc use have a greater strength......this is what the difference is between using a stock sleeve at 81mm vs a aftermarket sleeve at 84mm. I believe the aftermarket sleeves are ductile iron. </TD></TR></TABLE> yes they are made out of ductile iron and are much thicker then the stock sleeve. we cut the stock sleeve out and only leave a little aluminum to press the new braced sleeves in. the bracing not only gives the sleeves added strength but also helps keep them from going out of round. if you have anymore questions feel free to give me a call or pm me
Old Aug 19, 2008 | 03:30 PM
CerealKiller's Avatar
OP, like some have posted before, a sleeved block is much better than a stock.
Differences are on the material and design.
It all depends if you want to buy a core block or send in yours. Golden Eagle has a sale on their LS core blocks right now, do a search on here and it should show up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchtegman &raquo;</TD></TR><TR><TD CLASS="quote">i hope that doesnt happen to myblock.
goodluckm
I've sent my blocks to GE and have received all of them back, so yes, they send you what you sent them. Unless your buying a core. Like you I always write down my block information, before I sent them in, Just a habit.
Old Aug 19, 2008 | 03:39 PM
Default Re: (hatchtegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchtegman &raquo;</TD></TR><TR><TD CLASS="quote">what should i ask for? when i go to get my block sleeved. i have a 94 gsr block. i am using a gt37 or 40 r garret on 84 mm pistons build block cams the works tuned and lsd ect
;thanks
shane
</TD></TR></TABLE> just let who ever your going to use for sleeving know what bore you want and that its for turbo and you should be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchtegman &raquo;</TD></TR><TR><TD CLASS="quote">will i receive my block? or a pre-sleeved block or core as they call it?
</TD></TR></TABLE> we always sleeve your block and ship your block back to you but we do sell core sleeved b18a/b blocks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxcapacity &raquo;</TD></TR><TR><TD CLASS="quote">
My tuner got his block back from G eagle after sleeving and we don't know if it was throught the shipping process or what but by the time it got back the surface for the head had nasty scrape's, nick's and gouges on the edge near the oil passages.</TD></TR></TABLE> if there was a problem with the deck i hope he called us because we would never let it go like that and if it happen in shipping it is insured to cover ant problem that might happen during shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchtegman &raquo;</TD></TR><TR><TD CLASS="quote">i hope that doesn't happen to myblock.
goodluckm
</TD></TR></TABLE> we hot tank all the blocks we sleeve and if your going threw us we will sleeve and ship your block back to you and if there is any damage during shipping there insured to cover that so you will have no problems at all
Old Aug 20, 2008 | 03:28 PM
cool thank you Ge you answered my questions kpromply and to the point.
thanks
DCtooD
Jul 28, 2010 07:43 PM
92VXeg
Nov 21, 2008 10:28 AM
boostedb18kid
Jun 11, 2007 03:24 PM
satan_srv
Mar 19, 2003 01:52 PM
hydroflip
Oct 17, 2001 07:14 AM
