b20T crankcase ventilation
Old Oct 13, 2007 | 11:49 PM
t04b60-1's Avatar
Default b20T crankcase ventilation
setup is stock b20vtec without any pcv/catchcan. bnew garrett t3/t4 turbo.
-3 feed line with a restrictor, -10 oil return with a good angle.
sometimes i see oil in the compressor inlet. and turbine outlet. i'm assuming the excessively high crankcase pressure is doing this. i'm planning on putting two 1/2 fittings on the valve cover and a hose venting it on the atmosphere just pointing down. would this relieve my crankcase pressure? or do i need to tap a fitting on the back of the block?
any suggestions? just want the easiest way to do it.
Old Oct 14, 2007 | 05:11 PM
t04b60-1's Avatar
bump
Old Oct 14, 2007 | 09:28 PM
tony413's Avatar
this has been covered to many time look in FAQ
Old Jan 29, 2008 | 09:11 PM
boostedteg4dr's Avatar
Default Re: (tony413)
Im having the same problem. Oil is leaking from my ICP after the turbo......
I have the stock crankcase ventilation setup....
If you found a solution please let me know.
THANKS
93siturbod16
Apr 17, 2012 07:04 PM
mrchris1979
Dec 11, 2006 01:05 PM
B20-T
Feb 12, 2003 03:04 PM
T4sol
Aug 5, 2002 04:58 PM
*Boostwerks*
May 30, 2002 10:14 AM
