block guard
Old Feb 16, 2010 | 12:16 PM
93gsr4dr's Avatar
Default block guard
I was wondering what peoples opinion on a block guard are? I have heard some negative things about them not letting enough cooling through. I'm in the middle of a rebuild and was told to use one by a shop in my area. If someone could give me a little more info that would be great.
Old Feb 16, 2010 | 05:13 PM
lyncoors's Avatar
Default Re: block guard
not really worth it. they say to just resleeve
Old Feb 17, 2010 | 05:22 AM
93gsr4dr's Avatar
i know sleeving is the best thing to do. Can you run stock bore when you sleeve a engine?
Old Feb 17, 2010 | 05:54 AM
lyncoors's Avatar
yep. you can
Old Feb 17, 2010 | 06:01 AM
Psychoteen101's Avatar
Block guards are ok to run if you install them correctly. If you plan to stay stock bore, then i wouldnt risk installing a block guard..
Old Feb 18, 2010 | 06:36 AM
93gsr4dr's Avatar
ok. that helps alot. i will just sleeve the block then because i don't want to put all this time into rebuilding and turbo and then have a bad link that causes failure.
jeremiah87
Nov 19, 2008 02:17 PM
EJ1_228
Mar 25, 2008 11:26 PM
s2kdre
Apr 29, 2005 07:21 PM
menkio
Jun 12, 2004 10:37 AM
toooslow
Jul 10, 2003 08:31 AM
